    [SOLVED] CLASS! Consol ERROR!
    4 Posts 0 Posters 548 Views
      On 14/04/2017 at 19:51, xxxxxxxx wrote:
      Correct me, please!
      class Brakers() :
          """docstring for Brakers"""
          def __init__(self, nameCBD, nameCBI, nameCBC) :
              #self.nameParent = nameParent
              self.nameCBD = nameCBD
              self.nameCBI = nameCBI
              self.nameCBC = nameCBC
      def CreateBrakerDisk(self) :
              # добавляем ноль объект braker disc
              nameCBD = c4d.BaseObject(5170)
              nameCBD.SetName('eM ' + str(nameCBD)) # braker disc
              doc.InsertObject(nameCBD)
      def CreateBrakerInstance(self) :
              nameCBI = c4d.BaseObject(5126)
              nameCBI.SetName('eM ' + str(nameCBI))
              doc.InsertObject(nameCBI, nameCBD)
      def CreateBrakerConnector(self) :
              # добавляем ноль объект wheel connector
              nameCBC = c4d.BaseObject(180000011)
              nameCBC.SetName('eM ' + str(nameCBC))
              doc.InsertObject(nameCBC)
          brakers_1_1 = Brakers(brakers_1_1, brakers_inst_1_1, brakers_connect_1_1)
      Concol ERROR:
        File "'scriptmanager'", line 34, in <module>
        File "'scriptmanager'", line 30, in main
      UnboundLocalError: local variable 'brakers_1_1' referenced before assignment
        On 14/04/2017 at 21:49, xxxxxxxx wrote:
        I got it
        class Brakers() :
            def __init__(self) :
                pass
                self.nameCBD = c4d.BaseObject(5170)
                self.nameCBD.SetName('eM ' + str(self.nameCBD))
                doc.InsertObject(self.nameCBD)
                self.nameCBI = c4d.BaseObject(5126)
                self.nameCBI.SetName('eM ' + str(self.nameCBI))
                doc.InsertObject(self.nameCBI, self.nameCBD)
                self.nameCBC = c4d.BaseObject(180000011)
                self.nameCBC.SetName('eM ' + str(self.nameCBC))
                doc.InsertObject(self.nameCBC)
            brakers_1_1 = Brakers()
            brakers_1_1.CreateBrakerDisk()
            brakers_1_1.CreateBrakerInstance()
            brakers_1_1.CreateBrakerConnector()
        But name of objects
        eM <c4d.BaseObject object called 'Connector/Connector' with ID 180000011 at 0x000000000F572110>
        How rename it?
          On 15/04/2017 at 03:10, xxxxxxxx wrote:
          Hello for rename use SetName().
          How I know it?
          Simply go to the sdk. As you can read it's a c4d.BaseObject. So look at BaseObject class into the sdk.
          https://developers.maxon.net/docs/py/2023_2/modules/c4d/C4DAtom/GeListNode/BaseList2D/BaseObject/index.html?highlight=baseobject
          In inheritance you can see C4d.BaseList2D. Then click on it. (since baseobject inherit from BaseList2D a BaseObject have all the function BaseList2D got)
          And here you got SetName / GetName.
          Hope it's help you
            On 18/04/2017 at 01:21, xxxxxxxx wrote:
            Thank you! There is an easier way!
            def __init__(self, name = None, instance = 0, insertobject = None) :
                    self.name = name
                    self.instance = instance
                    self.insertobject = insertobject
