    Linkbox Setlink with data? [SOLVED]
    3 Posts 0 Posters 519 Views
      On 10/04/2017 at 14:33, xxxxxxxx wrote:
      Hi guys,
      I am trying to Load the data from the text file, read it and load it in to the link box. but it don't link what I tell it to find in the object manger, which is Cube.1 inside the .txt file. Plz tell what I am doing wrong in my code.
      This is what inside the .txt file.
      Cube.1
      The Code:
      Load = {"id": 1009, "name": "Open Settings"}
      SaveSettingsPath_in_field = 1011
      UI_TEMP_S1 = 1010
      class LinkBoxDialog(gui.GeDialog) :
          def CreateLayout(self) :
              self.MenuFlushAll()
              self.MenuSubBegin("Settings")
              self.MenuAddString(Load["id"], Load["name"])
              self.MenuSubEnd()
              self.MenuFinished()
              self.GroupBegin(34, c4d.BFH_MASK, rows=1)
              self.AddStaticText(203, c4d.BFH_CENTER, 0, 0, "Settings")
              self.Enable(203, False)
              self.AddEditText(SaveSettingsPath_in_field, c4d.BFH_MASK, 250, 10)
              self.GroupEnd()
              self.AddStaticText(0, c4d.BFH_CENTER, 0, 0, "TEMP 1.")
              self.rootLinkBaseContainer = c4d.BaseContainer()
              self.LinkBox1 = self.AddCustomGui(UI_TEMP_S1, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_CENTER, 250, 10, self.rootLinkBaseContainer)
              self.GroupEnd()
          def LoadSettings(self) :
              Load_Path = st.LoadDialog(type=c4d.FILESELECTTYPE_ANYTHING, title="Open Your Settings Folder Directory.", flags=c4d.FILESELECT_DIRECTORY, force_suffix=".txt")
              self.SetString(SaveSettingsPath_in_field, Load_Path)
              Get_Path = self.GetString(SaveSettingsPath_in_field)
              linkBox = self.FindCustomGui(UI_TEMP_S1, c4d.CUSTOMGUI_LINKBOX)
              data1 = open(os.path.join(Get_Path, 'Temp_Data_1.txt'), "r")
              read_txt = data1.readline()
              get_obj = doc.SearchObject(read_txt)
              linkBox.SetLink(get_obj)
          def Command(self, id, msg=None) :
              if (id == 1009) :
                  self.LoadSettings()
      plz help or tips would be really helpful to me.
      Ashton
        On 11/04/2017 at 09:39, xxxxxxxx wrote:
        Hi Ashton,
        the problem is, that the result of readline() contains the newline/linebreak at the end. Strip this from the string and your code works. Still I suggest to add error checks, where needed. Also makes debugging easier.
          On 11/04/2017 at 16:50, xxxxxxxx wrote:
          Thanks Andreas 🙂
          lol i had a next line which is line 2 lol
              # Save UI Settings to File
              def Save_UI_Settings(self) :
                  newpath = st.LoadDialog(type=c4d.FILESELECTTYPE_ANYTHING, title="Save Settings in a Directory.", flags=c4d.FILESELECT_DIRECTORY, force_suffix="")
                  self.SetString(SaveSettingsPath_in_field, newpath)
                  linkBox = self.FindCustomGui(1010, c4d.CUSTOMGUI_LINKBOX)
                  # Save Temp
                  with open(p.join(os.path.join(newpath, 'Temp_Data_1.txt')), 'w') as type_file:
                      LinkData = linkBox.GetLink().GetName()
                      type_file.write(LinkData+"\n") # <----------- I needed to Remove +"\n" it was making line 2 in the .txt
          So in my Load Settings, I now have it like this now.
                  linkBox.SetLink(doc.SearchObject(data1.readline()))
          So I Works Great on Loading! 🙂
          Thanks and Cheers,
          Ashton
