    Set attribute manager mode
    5 Posts 0 Posters 637 Views
      On 08/04/2017 at 07:09, xxxxxxxx wrote:
      Is it possible to set the attribute manager mode, via a script, for example?
      Would it need to be active/in focus first?
      It would be nice to have the modes as buttons or tabs for quicker/easier access.
      Maybe this post would be better suited for the plugin requests, I wasn't sure.
        On 08/04/2017 at 07:38, xxxxxxxx wrote:
        I guess this function is made for that.
        https://developers.maxon.net/docs/py/2023_2/modules/c4d.gui/index.html?highlight=manager#c4d.gui.ActiveObjectManager_SetObject
          On 08/04/2017 at 08:36, xxxxxxxx wrote:
          This seems to work sometimes, I made this super minimalist script
          https://github.com/NNNenov/C4Dhandy/blob/master/scripts/setAttributeManagerWindow.py
          In the cases it doesn't work, e.g. ACTIVEOBJECTMODE_TOOL;
          I have an editable poly cube and I set the attribute manager to a mode other than tool mode, when I execute the script with id as
          c4d.ACTIVEOBJECTMODE_TOOL
          It shows project settings mode instead, noticed this happens with other modes too. Maybe I didn't set up the script properly and it defaults to project settings mode..
            On 08/04/2017 at 08:58, xxxxxxxx wrote:
            Basicly c4d help you and set the mode according to the op you pass throught it.
            Here you have a quick exemple...
                #obj
                obj = op
                c4d.gui.ActiveObjectManager_SetObject(c4d.ACTIVEOBJECTMODE_OBJECT, obj, c4d.ACTIVEOBJECTMANAGER_SETOBJECTS_OPEN)
                #tag
                tag = op.GetTags()[0]
                c4d.gui.ActiveObjectManager_SetObject(c4d.ACTIVEOBJECTMODE_TAG, tag, c4d.ACTIVEOBJECTMANAGER_SETOBJECTS_OPEN)
                #mat
                mat = doc.GetActiveMaterial()
                c4d.gui.ActiveObjectManager_SetObject(c4d.ACTIVEOBJECTMODE_MATERIAL, mat, c4d.ACTIVEOBJECTMANAGER_SETOBJECTS_OPEN)
                #shader
                sha = mat.GetFirstShader()
                c4d.gui.ActiveObjectManager_SetObject(c4d.ACTIVEOBJECTMODE_SHADER, sha, c4d.ACTIVEOBJECTMANAGER_SETOBJECTS_OPEN)
                #tool
                tool = c4d.plugins.FindPlugin(doc.GetAction(), c4d.PLUGINTYPE_TOOL)
                c4d.gui.ActiveObjectManager_SetObject(c4d.ACTIVEOBJECTMODE_TOOL, tool, c4d.ACTIVEOBJECTMANAGER_SETOBJECTS_OPEN)
              On 08/04/2017 at 10:07, xxxxxxxx wrote:
              Ahh I see, that makes sense! thanks a lot!
