    delete layer
    3 Posts 0 Posters 436 Views
      On 07/04/2017 at 09:56, xxxxxxxx wrote:
      I was curious about the proper way to delete a layer with python. I know you can get the layer and do layer.Remove() which does delete the layer but it leaves the scene in a weird state sometimes. If I have objects solo'd when I use layer.Remove() it leaves all objects solo'd even though the layer is gone.
      Is there a proper way to go about this?
        On 10/04/2017 at 08:48, xxxxxxxx wrote:
        there's a small note in the Layer Manual in C++ docs that tells the trick.
        You basically need to clear the NBIT_SOLO_LAYER on the document, when removing a layer that has solo switched on.
        Like so:
            l = op.GetLayerObject(doc)
            if l is None:
            l.Remove()
            doc.ChangeNBit(c4d.NBIT_SOLO_LAYER, c4d.NBITCONTROL_CLEAR)
          On 10/04/2017 at 12:01, xxxxxxxx wrote:
          That did it, thanks Andreas!
