    drag parameter to user data field like in console
    5 Posts 0 Posters 1.3k Views
      On 28/03/2017 at 02:26, xxxxxxxx wrote:
      I'm trying to do something cheeky here, wondering if its possible.
      I want to make a python tag which performs an action on an object's parameters, but the user can define which parameter it is performed on by just dragging the parameter into a user data field;
      exactly like how we can drag a parameter or object into our python scripts or console.
      I thought I could do this with a string field but it doesn't let me, link field doesn't either.
      What makes the console input field so special, is there any way this could be done?
      cheers!
        On 29/03/2017 at 05:23, xxxxxxxx wrote:
        The Console input is an edit text that processes the drag and drop events for parameters. Same for the Script Manager except it's a multi-line edit text.
        You can create a String user data that uses the Multi-Line String Interface in Python mode (Check PYTHON in Details tab). The Multi-Line String GUI accepts dragged parameters.
        In code, DESC_CUSTOMGUI would be set to CUSTOMGUI_STRINGMULTI and DR_MULTILINE_PYTHON to 1.
        Then in the Python tag you can evaluate a dynamically built expression string generated with the String user data that contains the parameter ID.
        Here's some code:
            obj = op.GetObject()
            data = obj[c4d.ID_USERDATA,1]
            # Evaluates the parameter ID string
            # Returns a list of integers for the description levels
            paramID = eval(data)
            print paramID
            # Builds the expression obj[ID]
            expr = "obj" + data
            paramValue = eval(expr)
            print paramValue
          On 30/03/2017 at 11:39, xxxxxxxx wrote:
          Hey thank you that works great!
          I can now get the value of the dragged in parameter.
          But, if you wanted to set the evaluated parameter, how would you proceed?
            On 31/03/2017 at 07:25, xxxxxxxx wrote:
            You can set the evaluated parameter with  obj ->SetParameter( id, data, flags ).
            SetParameter() needs a complete DescID (with the DescLevel dtype filled) to effectively set a parameter.
            To get a full DescID, the best solution is to use Description.CheckDescID() (function added in R18).
            Here's some code:
                param = eval(data)
                desc = obj.GetDescription(c4d.DESCFLAGS_DESC_0)
                if desc is None:
                partialID = c4d.DescID()
                for level in param:
                    partialID.PushId(c4d.DescLevel(level))
                completeID = desc.CheckDescID(partialID, [obj])
                if completeID is None:
                obj.SetParameter(completeID, 100, c4d.DESCFLAGS_SET_0)
              On 31/03/2017 at 11:19, xxxxxxxx wrote:
              This really exciting, it works perfectly.
              I don't quite grasp whats happening with all this ID stuff, I need to read up on it!
              Thanks again!
