    PluginTag::GetPluginID() method
    3 Posts 0 Posters 401 Views
      On 16/03/2003 at 11:17, xxxxxxxx wrote:
      Cinema 4D Version:   8.1
      Hi all;
      I am trying to convert some (rather simple) plugins from version 7.3 to 8.1. Now, I am sorely missing a method:
      I get an object's tag list by
      GetFirstTag()
      Then I determine the type of the tag by
      GetType()==Tplugin
      Finally I want to check the plugin's ID. There used to be a method
      GetPluginID()
      , but it is gone (sez da compiler), with afaics no other method in the class hierarchy doing quite what I want (besides, the class PluginTag is a pretty good place to look for such a method).
      How do I get the plugin's registered ID? Not Tplugin, but the unique plugin-specific ID I (or someone else) got from Maxon. Where did that method move?
      -- Cairyn --
        On 18/03/2003 at 00:18, xxxxxxxx wrote:
        okay, after some debugging I found the solution.
        Apparently, the tag's method
        GetType()
        does no longer return the constant
        Tplugin
        for plugin tags, as it did in the V7.3 API, but the assigned ID instead.
        *sigh* I really wish someone would document changes in behaviour like that...
        -- Cairyn --
          On 18/03/2003 at 09:37, xxxxxxxx wrote:
          Thanks. Though the need for explicit R7 conversion docs should ideally become less over time, I'll at least make sure that Atom::GetType() gets the right description.
