    Create a tag plugin in submenu
    5 Posts 0 Posters 658 Views
      On 28/02/2017 at 21:05, xxxxxxxx wrote:
      when I create a tag plugin,it always appears in the tag menu.
      But I want it appears in a submenu,like the C4D tag.
      What should I do?😵
        On 01/03/2017 at 02:33, xxxxxxxx wrote:
        Which tag menu are you referring to? The Tags->CINEMA 4D Tags menu in the Object Manager?
          On 01/03/2017 at 03:13, xxxxxxxx wrote:
          Hi,Yannick Puech
          I just want to create a new tag menu,and put the tag plugin into my own menu.šŸ™‚
            On 02/03/2017 at 03:35, xxxxxxxx wrote:
            I'm afraid the Tags menu is dynamically created. Only if several Tag plugins are registered from the same plugin, then a sub menu is created for it.
            But you can add an item for your tag in another menu. This has to be done at startup of Cinema. For more information seeĀ Enhancing the Main Menu in the Python SDK docs.
              On 02/03/2017 at 20:51, xxxxxxxx wrote:
              Thanks for your help!šŸ‘
