    Layer Color other than given RGB
    4 Posts 0 Posters 473 Views
      On 23/02/2017 at 00:31, xxxxxxxx wrote:
      Hi there,
      I tried to set a Layer Color via
      > layer_data = layer.GetLayerData(doc)
      > layer_data['color'] = c4d.Vector(200,100,50)
      > layer.SetLayerData(doc,layer_data)
      If I take 255,0,0 as RGB-Values, it's a red one so this works basically.
      But the result of 200,100,50 is a white layer instead of a brown one.
      why?
        On 23/02/2017 at 04:59, xxxxxxxx wrote:
        in Vectors colors do usually get stored in floating point values ranging from 0.0 to 1.0 instead of integer values from 0 to 255.
          On 24/02/2017 at 00:56, xxxxxxxx wrote:
          k. are there other - maybe simpler than calculating from 0-255 to 0-1 - possibilities since the RGB-Values in the ColorChoosers are also from 0-255?
            On 24/02/2017 at 09:01, xxxxxxxx wrote:
            Converting 0-255 to 0-1.0 is only a matter of dividing the value by 255. Can't get much simpler than that
            Steve
