    How to update a variable in a dialog?
    5 Posts 0 Posters 753 Views
      On 11/02/2017 at 13:53, xxxxxxxx wrote:
      Hello there,
      How to update a variable in a dialog "CreateLayout(self)".
      in the script below I want to passing the value from the path field or the self.DIRECTORY to the variable "dirs".
      import c4d, re, os
      from c4d import gui
      class Dialog(c4d.gui.GeDialog) :
        SELECT_DIR = 40
        def CreateLayout(self) :
            self.GroupBegin(0,c4d.BFH_SCALEFIT,3,0,"");
            self.AddStaticText(0, c4d.BFH_RIGHT, 0, 0, "Path :", c4d.BORDER_NONE)
            **self.AddEditText(1, c4d.BFH_SCALEFIT, 250, 15)** **#Path to pass**
            self.AddButton(self.SELECT_DIR, flags=c4d.BFH_RIGHT,inith=15, name="...")
            self.GroupEnd()
            self.AddComboBox(1000, c4d.BFH_SCALEFIT, 0, 15)
            self.AddChild(1000,0,"Folders :&i" + str(c4d.RESOURCEIMAGE_OPENED) + "&" )
            self.AddChild(1000,0,"")
            **dirs = os.listdir(os.path.join( self.GetString(1))) # Passing the path value or the self.DIRECTORY here**
       **         # or** **:
            # dirs = os.listdir(os.path.join(** ** ** ** **self.DIRECTORY****** )) **
            id = 2000
            for plugin_name in dirs:
                self.AddChild(1000,id,plugin_name)
                id += 1
        def UpdateDlg(self, id) :
            self.SetString(1,self.DIRECTORY)
        def Command(self, id, msg) :
            if id == self.SELECT_DIR:
                **self.DIRECTORY** = c4d.storage.LoadDialog(flags=c4d.FILESELECT_DIRECTORY)
            self.UpdateDlg(self.GetLong(1000))
        def CoreMessage(self, id, msg) :
            if id==c4d.EVMSG_CHANGE:
                self.UpdateDlg(self.GetBool(self.DIRECTORY))
        global Dialog
        Dialog = Dialog()
        Dialog.Open(c4d.DLG_TYPE_MODAL, xpos=700, ypos= 200, defaultw=516, defaulth=10)
      I want to obtain this result:
        On 13/02/2017 at 01:49, xxxxxxxx wrote:
        To dynamically update the ComboBox children list, just call self.AddChild() in Command() with the sub-directories returned by os.listdir().
        The ComboBox is updated automatically because this doesn't change the layout of the dialog.
          Sorry, I wasn't clear on your response, please can you give me a small example?
          Thanks.
            Thanks.
            Simply move your loop with self.AddChild() from CreateLayout() to Command() and the if for the directory selection. CreateLayout() doesn't get called every time a command or an interaction in the dialog happens.
                dirs = os.listdir(os.path.join(self.GetString(1)))
                id = 2000
                    id += 1
              I tried this but nothing happen.
