    Image data containers [SOLVED]
    3 Posts 0 Posters 419 Views
      On 10/02/2017 at 02:43, xxxxxxxx wrote:
      Cinema 4D Version:   R14
      Hi all,
      could one of the fine folk here please provide an example of how we can set bitmap image data for proper 32bit images? Something like this (but in 32bit data land!) would help:
      // psuedo code
      void MyDialog::GetImageData(int width,int height,BaseBitmap* bmp)
          UCHAR *img = gNew UCHAR[width*height*3];
          // set one pixel to grey
          img[7*14 + 36 + 0] = 128; // R
          img[7*14 + 36 + 1] = 128; // G
          img[7*14 + 36 + 2] = 128; // B
          for(int h = 0; h < height;)
              bmp->SetPixelCnt(o,h,width,(UCHAR* )img[h * width],COLORBYTES_RGB,COLORMODE_RGB,PIXELCNT_0);
              h++;
          // free container etc.
      Also, could they clarify what data range the image data should be in? E.g. 0.0 - 1.0 or 0 - 4294967295.
      WP.
        On 13/02/2017 at 09:00, xxxxxxxx wrote:
        32-bit image data is stored as Float32 data:
        AutoAlloc<BaseBitmap> bitmap;
        if (!bitmap)
          return false;
        // define bitmap dimensions and bit depth
        const Int32 width  = 1024;
        const Int32 height = 1024;
        const Int32 pixelBytes = COLORBYTES_RGBf; // RGBf format
        const Int32 pixelBits  = pixelBytes * 8;
        // initialize the BaseBitmap with the given dimensions and bit depth
        const IMAGERESULT res = bitmap->Init(width, height, pixelBits);
        if (res != IMAGERESULT_OK)
          return false;
        // allocate memory for one line
        const Int32 bufferSize = width * 3;
        PIX_F*      lineBuffer = NewMemClear(PIX_F, bufferSize);
        if (!lineBuffer)
          return false;
        // loop through all lines
        for (Int32 y = 0; y <= height; ++y)
          // shade of red based on the position
          const Float32 red = Float32(y) / Float32(height);
          Int32 offset = 0;
          for (Int32 x = 0; x < width; ++x)
          // shade of green based on the position
          const Float32 green = Float32(x) / Float32(width);
          // fill buffer
          lineBuffer[offset] = red;
          lineBuffer[offset + 1] = green;
          lineBuffer[offset + 2] = 0.0;
          offset += 3;
          // write full line into the bitmap
          bitmap->SetPixelCnt(0, y, width, (UChar* )lineBuffer, pixelBytes, COLORMODE_RGBf, PIXELCNT_0);
        // delete line memory
        DeleteMem(lineBuffer);
          On 14/02/2017 at 02:27, xxxxxxxx wrote:
          Thanks Sebastian - that's got it working 👍
          WP.
