    Sweep a spline (pipe script)
    Scheduled Pinned Locked Moved Plugin Requests
    7 Posts 0 Posters 3.4k Views
      On 04/02/2017 at 08:53, xxxxxxxx wrote:
      Hello -
      I'm in need of a script that can instantly sweep a spline with a circle. This is something like a script I found a long time ago called pipoficator. For some reason it won't work right with the new R18. Any chance I can get help with this? Thanks so much.
      Greg
        On 06/02/2017 at 16:07, xxxxxxxx wrote:
        Coded in 5 min and I guess the code it's self explanatory but if you want more information feel free to ask 😉
            spline = op
            test_spline = spline.GetRealSpline()
            if not test_spline:
            doc.StartUndo()
            sweep = c4d.BaseObject(c4d.Osweep)
            doc.AddUndo(c4d.UNDOTYPE_NEW, sweep)
            sweep.InsertAfter(spline)
            doc.AddUndo(c4d.UNDOTYPE_HIERARCHY_PSR, spline)
            spline.InsertUnder(sweep)
            circle = c4d.BaseObject(c4d.Osplinecircle)
            circle[c4d.PRIM_CIRCLE_RADIUS] = 10 #change the radius of the circle here
            doc.AddUndo(c4d.UNDOTYPE_NEW, circle)
            circle.InsertUnder(sweep)
            doc.EndUndo()
          On 06/02/2017 at 23:25, xxxxxxxx wrote:
          I think, there's a small bug when adding the last undo step. There it probably should be circle instead of sweep.
            On 07/02/2017 at 08:37, xxxxxxxx wrote:
            Thanks I corrected it 🙂
              On 07/02/2017 at 18:22, xxxxxxxx wrote:
              gr4ph0s!!!! Thank you so much!!! You are awesome for doing that so quickly. Works great!
                On 07/02/2017 at 18:23, xxxxxxxx wrote:
                Andreas Block, thank you for your help as well!
                  On 07/02/2017 at 23:42, xxxxxxxx wrote:
                  Hi Greg,
                  I've not done much here. But, please, just Andreas is enough.
