    [SOLVED]Can i Isolate Each Object?
    4 Posts 0 Posters 620 Views
      On 27/01/2017 at 04:56, xxxxxxxx wrote:
      hi guys,
      hope y'all are great are doing great,
      So is it possible to  isolate each object?
      because c4d.documents.IsolateObjects(doc, T_obj) dont work when using like this
          if doc == None:
              return False
          # Get Models form the Object Manager
          objs = doc.GetActiveObjects(1)
          if not objs:
              gui.MessageDialog("Select objects")
              return False
          for E in objs:
              doctemp = c4d.documents.IsolateObjects(doc, E)
              if doctemp == None:
                  return False
      but it ask for all objects which is objs.
      so it look this :
      doctemp = c4d.documents.IsolateObjects(doc, objs)
      and that what it likes but it do all of them , what i want is each object when execute.
      so its like each object go in it own folder.
      plz help and i hope this was understandable to y'all.
      Ashton
        On 27/01/2017 at 06:13, xxxxxxxx wrote:
        The new doc created with isolateObject is not inserted in the list of user doc.
        Here an exemple of something I wrote in 5 min and 3months ago(that mean he could have some errors and its not well documented...).
        import os
            current_dir = doc.GetDocumentPath()
            buffer_path = None
            list_obj = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_0)
            if not list_obj:
            new_doc = c4d.documents.IsolateObjects(doc, list_obj)
            c4d.documents.InsertBaseDocument(new_doc)
            if not current_dir:
            buffer_path = os.path.join(current_dir,"file_buffer.c4d")
            c4d.documents.SaveDocument(new_doc, buffer_path, c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST, c4d.FORMAT_C4DEXPORT)
            path = c4d.storage.LoadDialog(flags = c4d.FILESELECT_DIRECTORY)
            if not path:
            filename = c4d.gui.InputDialog("Nom du dossier", "Dossier")
            if not filename:
            assets = list()
            missingAssets = list()
            path = str(os.path.join(path,filename))
            c4d.documents.SaveProject(new_doc, c4d.SAVEPROJECT_SCENEFILE | c4d.SAVEPROJECT_ASSETS | c4d.SAVEPROJECT_PROGRESSALLOWED | c4d.SAVEPROJECT_DIALOGSALLOWED | c4d.SAVEPROJECT_SHOWMISSINGASSETDIALOG, path, assets, missingAssets)
            if buffer_path:
                os.remove(buffer_path)
            if missingAssets:
                gui.MessageDialog("Missing Asset\n" + str(missingAssets))
            #c4d.documents.KillDocument(new_doc)
          On 27/01/2017 at 14:41, xxxxxxxx wrote:
          Hi gr4ph0s
          I like what your code is doing but its really like this:
          if I have 4 cubes in the scene , and select them I want them to export each object separately as a export file like .dae
          so i would have:
          Cube.dae
          Cube1.dae
          Cube2.dae
          Cube3.dae
          in the folder I send it too.
          problem is i need each object to Isolate it self and continue the process.
            On 28/01/2017 at 13:44, xxxxxxxx wrote:
            thanks I got it.😉
            I was missing this :
                    get_E = E.GetName()
                    fobj = doc.SearchObject(get_E)
                    sobj = doc.SetActiveObject(fobj)
                    get = doc.GetSelection()
                    new_doc = c4d.documents.IsolateObjects(doc, get)
            cheers 🙂
