    [SOLVED]LoadDialog / SaveDialog prefilled filename
    5 Posts 0 Posters 772 Views
      On 25/01/2017 at 08:03, xxxxxxxx wrote:
      Is there a way for set the default filename for a loadDialog or a saveDialog ?
      By reading hte sdk and doing some test it's look like not but maybe I missunderstand something.
      If not it will be a nice feature to have.
      Thansk in advance 🙂
        On 26/01/2017 at 06:19, xxxxxxxx wrote:
        unfortunately not, currently. This is a current limitation of the Python implementation. I filed a feature request.
          On 26/01/2017 at 06:47, xxxxxxxx wrote:
          Thanks for the answer.
          Moreover is their a working solution in C++? I was not able to find the equivalent c++ class of the storage python module.
            On 26/01/2017 at 07:33, xxxxxxxx wrote:
            Yes, there is. It's in the Filename class the FileSelect function. You just need to set the different parts of a Filename (SetDirectory() and SetFile()) to get the desired result.
              On 01/02/2017 at 00:59, xxxxxxxx wrote:
              As a workaround I coded an small application in autoit (windows only but it's not important since mac os FileDialog don't have a filename field).
              So basicly my autoit code wait a specific windows. And when it find it it write the argument into the name field.
              It's not the proper way but it's working.
              Here my autoit code -you can find information about compiling and more here => https://www.autoitscript.com/site/autoit/
              AutoItSetOption("SendKeyDelay",0)
              AutoItSetOption("SendKeyDownDelay",0)
              ;#Wait 100000s a windows named Texture Manager Replace
              If WinWait("My unique UI name Replacer", "", 100000) Then
              	;Send arguments to this windows in EDIT1 field (fieldname)
              	ControlSend("Texture Manager Replace", "", "Edit1", $CmdLineRaw)
              EndIf
              And here my python I used subprocess since c4d.storage.GeExecute don't seem to allow arguments
              import subprocess
              import platform
              if platform.system() == "Windows":
                  subprocess.Popen([os.path.join(dir, "writter.exe"), "text to fill"])
                  new_file = c4d.storage.LoadDialog(c4d.FILESELECTTYPE_IMAGES, "My unique UI name Replacer", c4d.FILESELECT_LOAD)
