    Start a render with script
    3 Posts 0 Posters 487 Views
      On 13/01/2017 at 09:38, xxxxxxxx wrote:
      Hi ,
      I have mad a simple script to change the save path  , but to increase the functionality of the script I would like to make the script start the render in the picture viewer when clicked .
      is this possible ?
      if it is possible in which part of documentation I can find about it , because the render documentation only described the render settings ....
        On 13/01/2017 at 10:32, xxxxxxxx wrote:
        The simplest way to start a render is using this: c4d.CallCommand(12163) #R13 Render View command
        But there is also the RenderDocument() function.
        https://developers.maxon.net/docs/py/2023_2/modules/c4d.documents/index.html?highlight=renderdocument#c4d.documents.RenderDocument
          On 13/01/2017 at 11:33, xxxxxxxx wrote:
          thank you very much 😄
          I forgot about the script log , in my case it was   :
            c4d.CallCommand(12099, 12099) # Render to Picture Viewer
