    Accessing V-Ray Material Parameters [SOLVED]
    4 Posts 0 Posters 463 Views
      On 04/01/2017 at 02:22, xxxxxxxx wrote:
      Cinema 4D Version:   16+
      Platform:      Mac OSX  ;
      Hi there,
      I simply cannot get this to work. Please help!
      I try to set the color and to exchange Texture links within an Advanced VRay material and its Advanced Bitmap Shader.
      This is what I have so far (getting the link to a V-Ray Advanced Material from a Texture-Tag and trying to read out the shader loaded to the Diffuse Layer 1 -> Diffuse Color Texture slot) :
      BaseTag* TexTag = MyObjekt->GetTag(Ttexture);
      if (TexTag)
           BaseMaterial* Material = ((TextureTag* )TexTag)->GetMaterial(true);
           if (Material)
                if (Material->GetType() == 5703)
                     // Material is of Type V-Ray Advanced Material
                     GeData Vray_data;
                              Material->GetParameter(DescID(4100), Vray_data, DESCFLAGS_GET_0); // VRAYMATERIAL_COLOR1_SHADER -> Texture link field in the material
                              BaseShader *shader = static_cast<BaseShader*>(Vray_data.GetLink(doc, 0));
        On 05/01/2017 at 01:42, xxxxxxxx wrote:
        Hi Arndt, thanks for writing us.
        With reference to your code I'd say it looks fine at a least from a Cinema 4D SDK point of view. So I guess, there must be something happening on the V-Ray implementation side. Unfortunately the MAXON SDK Support team has no information about it, hence I suggest you to directly ask the VRAYforC4D guys (LAUBlab) or somebody in our community can help out.
        As side note please I also invite you to make use of the
        tag to include your code snippets in order to improve code readability.
        Best, Riccardo
          On 05/01/2017 at 06:11, xxxxxxxx wrote:
          Hi Riccardo,
          thanks for your reply. I will try to contact LaubLab directly then.
            On 06/01/2017 at 05:46, xxxxxxxx wrote:
            Hi Arndt,
            may be try this code instate.
            BaseTag* TexTag = Mein Objekt->GetTag(Ttexture);
            if (TexTag) {
              BaseMaterial* Material = static_cast<TextureTag*>(TexTag)->GetMaterial(true);
              if (Material) {
                  if (Material->GetType() == 1020295) {
                      // Material ist ein V-Ray Advanced Material
                      BaseContainer *bc = Material->GetDataInstance();
                      BaseShader *shader = static_cast<BaseShader*>(bc->GetLink(VRAYMATERIAL_COLOR1_SHADER, doc));
