    Cannot export to FBX from command line
    14 Posts 0 Posters 2.3k Views
      On 02/01/2017 at 07:40, xxxxxxxx wrote:
      Hi there,
      I'm creating a python script that exports a scene to FBX that I want to use by running C4D with -nogui from the command line.
      The issue I get is that calling
      documents.SaveDocument(documents.GetActiveDocument(), [PATH], [FLAGS], FBX_EXPORTER_ID)
      ( with FBX_EXPORTER_ID = 1026370 )
      returns true but does not write a file, whereas
      documents.SaveDocument(documents.GetActiveDocument(), [PATH], [FLAGS],c4d.FORMAT_C4DEXPORT)
      does work as expected.
      Using c4d.FORMAT_OBJ does not work either.
      The same script used in a command plugin exports to FBX properly when C4D is not in background mode.
      I'm guessing this is a bug, or am I doing anything wrong ?
      here's the script : https://gist.github.com/anonymous/c971f8f431de9de41ba632ce6d6d9ab2
      Thanks !
        On 02/01/2017 at 08:16, xxxxxxxx wrote:
        Get a look to this https://github.com/PluginCafe/cinema4d_py_sdk/blob/master/scripts/FileImportExport/export_OBJ.py
        You can do the exact same thing with fbx just check the type in the c++ sdk since they are not listed in the python one.
        https://developers.maxon.net/docs/cpp/2023_2/\_ffbxexport_8h.html
          On 03/01/2017 at 03:33, xxxxxxxx wrote:
          Hi Thomas,
          To export an FBX from command line, SaveDocument() has to be called from another thread.
          Here's the solution:
          from c4d import documents, threading
          import sys
          class ExportThread(threading.C4DThread) :
              def __init__(self, doc) :
                  self.doc = doc
                  self.status = False
              def Main(self) :
                  # Export document to FBX
                  self.status = documents.SaveDocument(self.doc, DEST_FILE, c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST, FBX_EXPORTER_ID)
              def GetStatus(self) :
                  return self.status
          def ExportFBX() :
              # Load document
              load = documents.LoadFile(SOURCE_FILE)
              if not load:
                  return False
              # Get loaded document
              if doc is None:
                  return False
              # Clone document
              clone = doc.GetClone(c4d.COPYFLAGS_DOCUMENT)
              if clone is None:
                  return False
              thread = ExportThread(clone)
              thread.Start()       # Start thread
              thread.End()         # Then end it but wait until it finishes
              # Retrieve export status and return it
              status = thread.GetStatus()
              return status
          def PluginMessage(id, data) :
              if id==c4d.C4DPL_COMMANDLINEARGS:
                  if 'ExportFBX' in sys.argv:
                      print "FBX Export Started"
                      ret = ExportFBX()
                      if ret:
                          print "FBX Export Succeeded"
                          print "FBX Export Failed!"
              return False
          To test this code save it to a pyp file in your plugins directory. Then run Cinema 4D's in Command Line passing "ExportFBX" argument.
          The thread solution also works well and is fast when Cinema 4D interface is running.
            On 03/01/2017 at 07:29, xxxxxxxx wrote:
            Hi Yannick, thanks for your reply. Unfortunately this did not work,
            I ran your plugin with
            /Applications/MAXON/CINEMA\ 4D\ R18/CINEMA\ 4D.app/Contents/MacOS/CINEMA\ 4D -nogui ExportFBX
            Then did get
            But no file was written. Again, using
            FBX_EXPORTER_ID = c4d.FORMAT_C4DEXPORT
            does write a file.
            I'm wondering if the FBX exporter's id 1026370 is still valid.. but couldn't find it in the C++ SDK as gr4ph0s suggested.. although it works when the interface is running.. I'm using R18 btw.
              On 03/01/2017 at 08:54, xxxxxxxx wrote:
              The FBX exporter ID is fine. I tested the code I posted on Windows but not on Mac.
              Have you tried to execute Commandline.app instead of Cinema 4D.app? This app should be used instead of the normal one for Command Line operations.
                On 04/01/2017 at 07:41, xxxxxxxx wrote:
                Hi Yannick,
                Well, still no luck here, even on Windows with R18. However, the file exports fine with R15.  Which version did you use ? I'm going to try on R17 now.
                  On 04/01/2017 at 07:48, xxxxxxxx wrote:
                  Also working with R17, can you confirm you get the same result with R18 on your side ?
                    On 04/01/2017 at 09:46, xxxxxxxx wrote:
                    I confirm there's an issue exporting FBX files in command line with R18 indeed. It will be fixed with the next update.
                      On 04/01/2017 at 10:06, xxxxxxxx wrote:
                      Alright, Is there a bug tracker or do you have a rough idea when this will be available ?
                      Thanks a lot for your help!
                        On 05/01/2017 at 04:33, xxxxxxxx wrote:
                        There's only an internal bug tracker. Hopefully an update will be released soon.
                          On 06/01/2017 at 10:37, xxxxxxxx wrote:
                          Hi I ran into another problem and I couldn't find a solution, it seems that C4D will try to load any file which path is passed as an argument.
                          For example :
                          "/Applications/MAXON/CINEMA 4D R17/Commandline.app/Contents/MacOS/Commandline"  -ExportFBX -src "[absolute path]/testScene.c4d" -dst "[absolute path]/testScene.fbx"
                          crashes C4D, apparently because it's trying to load the fbx.
                          "/Applications/MAXON/CINEMA 4D R17/Commandline.app/Contents/MacOS/Commandline" "[absolute path]/testScene.fbx"
                          crashes it too.
                          I tried to "consume" arguments in sys.arg in pluginMessage(id=C4DPL_COMMANDLINEARGS) but the crash occurs before that.
                          So far, the only way I found arround that is to omit the file extension in the paths provided as arguments
                          For example :
                          "/Applications/MAXON/CINEMA 4D R17/Commandline.app/Contents/MacOS/Commandline"  -ExportFBX -src "[absolute path]/testScene" -dst "[absolute path]/testScene"
                          Then i can append the file extensions in the script but I have to assume the file extension is lower case, Is there a better way ?
                          Thanks.
                            On 09/01/2017 at 08:42, xxxxxxxx wrote:
                            Hi Thomas,
                            The sys.argv command line arguments passed to C4DPL_COMMANDLINEARGS plugin message can't be consumed currently.
                            I'll see if a better workaround can be used to avoid Cinema 4D from loading filenames passed as command line arguments.
                              On 08/03/2017 at 05:51, xxxxxxxx wrote:
                              Hi Thomas,
                              Sorry for my late reply.
                              A workaround to avoid Cinema from recognizing file paths is to merge the command switches -src and -dst with the file names in the same strings, for instance:
                              -ExportFBX "-src [absolute path]/testScene.c4d" "-dst [absolute path]/testScene.fbx"
                              The string can then be split like this:
                              srcSwitch, srcFile = arg.split(' ', 1)
                              if srcSwitch != '-src':
                                  return False
                              # This line is needed to fix spaces on OSX
                              srcFile = srcFile.replace('\\ ', ' ')
                                On 01/08/2017 at 04:22, xxxxxxxx wrote:
                                ~~I am running into this problem as well in R18 (SP3); both Commandline and -nogui options will return true for the save command but no FBX file is written.
                                Any new information on a resolution would be wonderful, if available.
                                Thanks!
                                EDIT:
                                I retract this; after updating I had not retried a thread solution. I can confirm The ExportFBX example provided in this thread works properly for both Commandline and -nogui in Cinema 4D R18.057, resulting in a file being written.
