    Enable / Disable button
    4 Posts 0 Posters 610 Views
      On 31/12/2016 at 21:05, xxxxxxxx wrote:
      Hello there,
      How can I disable a button if the selected object not an editable object, the example below do that but not exactly what I want. In the example below if I select anther object without closing the dialog, nothing is happening.
      I want to autoupdate the enabling or disabling of the button without closing and reopening the dialog if I select anther object
      I hope that is clear.
      import c4d, os
      from c4d import gui, documents, plugins
      PLUGIN_ID = 1234567
      class MyDLG( c4d.gui.GeDialog) :
        def UpdateDlg(self, id) :
            op = doc.GetActiveObjects(False)[0]
            **if op.GetType() != 5100 :
                self.Enable(1000,False)**
        def CreateLayout(self) :
            self.SetTitle("Texel Bake")
            self.AddButton(1000, c4d.BFH_SCALEFIT, 0, 13, "Button")
        def InitValues(self) :
            self.UpdateDlg(self.GetBool(1000))
      class MyPlugin(c4d.plugins.CommandData) :
        def Execute(self, doc) :
            global RunDLG
            RunDLG = MyDLG()
            RunDLG.Open(dlgtype=c4d.DLG_TYPE_ASYNC, defaultw=0, defaulth=0)
        help = ""
        icon = c4d.bitmaps.BaseBitmap()
        fn = os.path.join(dir, "res", "icon.tif")
        icon.InitWith(fn)
        plugins.RegisterCommandPlugin(PLUGIN_ID, "My Plugin", 0, icon, help, MyPlugin())
      Thanks.
        On 01/01/2017 at 08:10, xxxxxxxx wrote:
        Use the timer function of gedialog
        import c4d, os
        PLUGIN_ID = 1234567
                self.SetTimer(250)
                if not op:
                if op[0].GetType() != 5100 :
                    self.Enable(1000,True)
            def Timer(self, msg) :
        a = MyDLG()
        a.Open(c4d.DLG_TYPE_ASYNC)
        Moreover another tips never do op = doc.GetActiveObjects(False)[0]
        Check if op is not None before 😉
          On 02/01/2017 at 03:18, xxxxxxxx wrote:
          Using a timer works but I think catching EVMSG_CHANGE is a better solution:
              def CoreMessage(self, id, msg) :
                  if id==c4d.EVMSG_CHANGE:
          Also calling c4d.EventAdd() inside the Execute() of the command plugin is unnecessary.
            On 02/01/2017 at 07:57, xxxxxxxx wrote:
            Thank you guys for your replies.
