    CompositingTag
    2 Posts 0 Posters 435 Views
      On 09/03/2003 at 03:59, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Is there a way to set the Global Illumation in the CompositingTag
      I try things like that:
      my_container -> SetData(COMPOSITINGTAG_SEEN_BY_GI,FALSE);
      my_container -> SetData(COMPOSITINGTAG_SEENGI,FALSE);
      my_container -> SetData(COMPOSITINGTAG_SEEN_BY_GLOBAL-ILLUMINATION,FALSE);
      But it is not working....
        On 09/03/2003 at 13:57, xxxxxxxx wrote:
        The correct name is COMPOSITINGTAG_SEENBYGI but it returns an error ("variable or function expected !"), so you just have to replace this name by the ID value 1017 and it works !
        my_container -> SetData(1017,FALSE);
        You can find all IDs for each parameter in the C4D path:
        *Resource\res\description* then, in your case, open the file Tcompositing.h. ("T" for TAG"...)   in a text editor.
        When the ID name doesn't work, try the corresponding ID value.
        Bon courage pour la suite Platane !
