    [SOLVED]Know the change of bitmap
    16 Posts 0 Posters 2.9k Views
      On 19/12/2016 at 09:09, xxxxxxxx wrote:
      When you call GenerateTexturePath() pass an empty string for suggestedfolder instead of None. This way the the expected texture filename will be returned.
      And GenerateTexturePath() doesn't just concatenate path and file names. It's really more complex then that and performs the steps you quoted in your initial post.
      Materials, not shaders, are assigned to objects. So you can only check if a material is used, then you can discard it and all its shaders.
      To check if a material is used, retrieve the state of its BIT_MATMARK like this:
      # First, reset BIT_MATMARK of all materials
      mat = doc.GetFirstMaterial()
      while mat:
          mat.DelBit(c4d.BIT_MATMARK)
          mat = mat.GetNext()
      # Send MSG_MULTI_MARKMATERIALS message to document
      if doc.MultiMessage(c4d.MULTIMSG_ROUTE_BROADCAST, c4d.MSG_MULTI_MARKMATERIALS) :
          while mat:
              # Check BIT_MATMARK
              print "Material '" + mat.GetName() + "' Used: ", mat.GetBit(c4d.BIT_MATMARK)
              mat = mat.GetNext()
        On 19/12/2016 at 09:42, xxxxxxxx wrote:
        Thanks about GenerateTexturePath() gonna try on huge scene to check if it's slower than my implementation or not. (Since I'm not at work I will answerd to this only in few week but anyway thanks for the tips).
        And it's seem to check if the file exist?Is it trustable or it's better to do a os.path.exists after it?
        Does it also, check if presset exist? This could be a really better workaround for me to check presset file with this function than with the one I did before.
        About the second point I really speak about shader not material.
        It's like someone have done this.
        shd = c4d.BaseList2D(c4d.Xbitmap)
        mat.InsertShader(shd)
        So that lead to a shader who is inserted into a material but wich is not used at anytime...
        But your script would be usefull for another project then thanks you ! 🙂
          On 20/12/2016 at 03:55, xxxxxxxx wrote:
          Yes GenerateTexturePath() checks if the texture file exists.
          That's not what GenerateTexturePath() is meant to do. It returns the full path to a texture or another asset used in a document.
          Thanks for the explanation. Checking if a shader inserted into a material is really used is a complex task.
          The easiest checks would be to test if the shader is used in any of the material's channel.
            On 04/01/2017 at 03:28, xxxxxxxx wrote:
            Thanks for the answer.
            Finally I managed to get it working pretty fast and the most important not so much related to textures count using a combination of methods.
            I list all textures and try to find them in all searchPath(see first post for know wich one).Like that I do only 1 os.walk(wich is the slower part of the code of course) and then for extra_checking I do GenerateTexturePath for some missings textures.
            This finally give me the same output as the Texture manager from c4d.
            But mine load in 18sec, where it took 1min30 with the default texture manager.
            Moreover is there a way for use GenerateTexturePath not on the main thread? Because for the moment even if I use my own thread it's freeze everything 😕
            Here is some code maybe it would be more understandable, ofc this not my full code, even if I plan for a final open source project I would release it when it will be full working.
            #here my threading attemps
            class MyThread(c4d.threading.C4DThread) :
                utility = Utility()
                texture_found = list()
                texture_to_relocate = list()
                texture_not_found = list()
                create_ui = None
                def Main(self) :
                    c4d.StatusSetSpin()
                    self.texture_found, self.texture_to_relocate, self.texture_not_found = self.utility.get_texture_data(self.Get())
                    c4d.StatusClear()
            #the main function only a little part
            class Utility(object) :
                def get_texture_data(self, thread) :
                    all_tex = self.__get_all_texture()
                    texture_found = []
                    texture_to_relocate = []
                    texture_not_found = []
                    docpath = doc.GetDocumentPath()
                    suggestedfolder = str()
                    for tex in all_tex:
                        texture = c4d.GenerateTexturePath(docpath, tex["path"], suggestedfolder, bt=thread)
            #And where I make the lunch of my Dialog
            class Dialog(c4d.gui.GeDialog) :
                utility = Utility()
                can_be_closed = True
                thread_get_texture = None
                def get_all_textures(self, is_update) :
                    self.can_be_closed = False
                    c4d.StatusSetSpin()
                    self.thread_get_texture = MyThread()
                    if is_update:
                        self.thread_get_texture.create_ui = False
                        self.thread_get_texture.create_ui = True
                    self.thread_get_texture.Start()
                def CreateLayout(self) :
                    ###SOME STUFF###
                    self.get_all_textures(False)
            Thanks in advance ! 🙂
              On 05/01/2017 at 04:45, xxxxxxxx wrote:
              With a similar code I can't get a freeze calling c4d.GenerateTexturePath() on a custom thread.
              So I don't think the issue is inside the code you posted.
              How do you check the custom thread has finished its processing?
                On 05/01/2017 at 06:17, xxxxxxxx wrote:
                I simply not check.
                When the code is over at the end of my function I do A specialEventAdd()
                Then in my dialog I catch this event and fill my UI.
                I uplaoded on github a bigger part of my code. It's not 100% bug free, but I hope this will help you to understand a litlle bit better how everything works.
                https://github.com/gr4ph0s/C4D-TextureChecker
                Anyway thanks in advance ! 🙂
                  On 10/01/2017 at 06:06, xxxxxxxx wrote:
                  Ok don't know exactly what change made this happen(you know this feling when something work when normally it should not ^^) but now my code is really executed into another thread so my UI is not anymore freezing.
                  I still get some crash regarding threading but it's 100% an error from me, I will came back if I don't find the solution.
                  I got another question. In our library we got some corrompteds textures. Wich load to an incapability of C4D to export/use them. Is there an easy way for find those textures excepting with a basebitmap->InitWith? (wich is pretty slow on big file).
                  Is there a way for listing all assets in a library (tipicaly do a os.walk on preset?) like that I could remove the corrompted data from the library.
                  Thanks in advance 🙂
                  EDIT:
                  I have figure out which line make c4d crash.
                  def __test_valid_picture(self, picture_path) :
                  	ascii_path = picture_path.encode('utf8')
                  	result = self.bmp.InitWith(ascii_path) #crash here
                  	self.bmp.FlushAll()
                  	if result[0] == c4d.IMAGERESULT_OK:
                  		return False
                  The weirdest thing is I checked more than 350 textures. And c4d crash always with the same one. So maybe is not a crash related to the thread but to the texture (wich is 100% ok, render fine when appliqued to a plan).
                  And it's not crashing everytime. Sometime the problematic texture load correctly and not crash c4d.
                  I also updated the github if you want to check 😉
                  I still have to do some code cleanup.
                  EDIT 2:
                  Executing the code posted previously from the main thread don't seem to crash.
                  EDIT 3:
                  Having only the problematic texture in the scene and with my multi-threaded code it's seem to not crash
                  The most strange thing it's crashing while he already loaded the bitmap. And it seem to always crash on the 4th iteration of the map.
                  Look at my screen http://img11.hostingpics.net/pics/432714crash.png and I get this code
                          print 'b'
                          result = bmp.InitWith(ascii_path)
                          print 'a'
                          bmp.FlushAll()
                          del(bmp)
                              return False
                  Is their some threading limitation for using InitWith in a custom thread?
                    On 13/01/2017 at 06:56, xxxxxxxx wrote:
                    Sorry for the triple post.
                    But GenerateTexturePath on another thread when image don't exist make c4d crash.
                    Here is a short exemple that make c4d crash
                    # encoding: utf-8
                    import os
                    from ctypes import pythonapi, c_void_p, py_object
                    PLUGIN_ID = 1038562
                            bmp.FlushAll()
                            del(bmp)
                                return False
                            path = "qsdsqdsdqdqzz.jpg" #random name. in the case where picture don't exist.
                            texture = c4d.GenerateTexturePath(docpath, path, suggestedfolder, bt=thread) #this line crash
                            self.__test_valid_picture(path)
                        def Main(self) :
                            c4d.StatusSetSpin()
                            self.get_texture_data(self.Get())
                            c4d.StatusClear()
                            c4d.SpecialEventAdd(PLUGIN_ID, p1=1)
                            c4d.StatusSetSpin()
                            if self.thread_get_texture is None:
                                self.thread_get_texture.Start(c4d.THREADMODE_ASYNC)
                                self.thread_get_texture.End(True)
                        def AskClose(self) :
                            self.thread_get_texture.need_to_close = True
                            return False
                        def CoreMessage(self, id, msg) :
                            if id == PLUGIN_ID:
                                P1MSG_UN = msg.GetVoid(c4d.BFM_CORE_PAR1)
                                pythonapi.PyCObject_AsVoidPtr.restype = c_void_p
                                pythonapi.PyCObject_AsVoidPtr.argtypes = [py_object]
                                P1MSG_EN = pythonapi.PyCObject_AsVoidPtr(P1MSG_UN)
                                if P1MSG_EN == 1:
                                    if self.thread_get_texture.IsRunning() :
                                        self.thread_get_texture.End()
                                    self.can_be_closed = True
                    class Launcher(c4d.plugins.CommandData) :
                        dialog = None
                        def Execute(self, doc) :
                            if self.dialog is None:
                                self.dialog = Dialog()
                            return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=200, defaulth=50, xpos=-1,
                                                    ypos=-1)
                        def RestoreLayout(self, sec_ref) :
                            return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref)
                        c4d.plugins.RegisterCommandPlugin(PLUGIN_ID, "00 - Texture Manager", 0, None, None, Launcher())
                    Thansk in advance ! 🙂
                      On 16/01/2017 at 02:31, xxxxxxxx wrote:
                      Thanks for posting the code.
                      I'm afraid there's an internal issue passing bt thread parameter of c4d.GenerateTexturePath().
                      This bug will be fixed.
                        On 16/01/2017 at 03:29, xxxxxxxx wrote:
                        Using the python threading module can be a workaround? And is it really bad to use python threading module instead of the c4d one?
                        Moreover this fix will be aviable in all c4d versions(all version contening this functions ofc) or just R18?
                        Anyway thanks for your answer 🙂
                          On 17/01/2017 at 03:26, xxxxxxxx wrote:
                          Using the python threading module can't be a workaround because GenerateTexturePath() only accepts a BaseThread.
                          It's recommended to use the c4d.threading classes from the Cinema Python API because these are the supported internally.
                          Note we don't backport fixes to past releases of Cinema 4D. So GenerateTexturePath() will be fixed in the next update of R18 and future releases.
                            On 17/01/2017 at 03:36, xxxxxxxx wrote:
                            Thanks for the infos !
