    How to get the splineobject of primitives?[SOLVED]
    9 Posts 0 Posters 905 Views
      On 14/12/2016 at 08:23, xxxxxxxx wrote:
      Hey,
      I hope it´s a noobish question. I´d like to get the splineobject with tangents of a primitiv, for example circle.
      This is what I already tried:
      import os
      import math
      import sys
      from c4d import plugins, utils, bitmaps, gui
      PLUGIN_ID = 123455589
      class TEST(plugins.ObjectData) :
        def Init(self, node) :
        def GetVirtualObjects(self, op, hierarchyhelp) :
            child = op.GetDown()
            if not child: return None
            print child.GetCache()
            res = c4d.utils.SendModelingCommand(
                command = c4d.MCOMMAND_MAKEEDITABLE,
                list = [child.GetClone()],
                mode = c4d.MODELINGCOMMANDMODE_ALL,
                bc = c4d.BaseContainer(),
                doc = op.GetMain())[0]
            print res
                command = c4d.MCOMMAND_CURRENTSTATETOOBJECT,
            print res, res.GetPointCount()
            print op.GetAndCheckHierarchyClone(hierarchyhelp,child,c4d.HIERARCHYCLONEFLAGS_ASSPLINE,False)["clone"]
            return None
        icon = bitmaps.BaseBitmap()
        icon.InitWith(os.path.join(dir, "res", "TEST.tif"))
        plugins.RegisterObjectPlugin(id=PLUGIN_ID, str="TEST2",
                                    g=TEST,
                                    description="TEST2",
                                    info=c4d.OBJECT_GENERATOR,
                                    icon=icon)
      But
      (first print) returns <c4d.LineObject object called 'Circle' with ID 5137 at 0x0000000012661C70>,
      print res
      (second print) returns <dead c4d.SplineObject object at 0x0000000012661DB0>
      print res
      (third print) returns <c4d.SplineObject object called 'Circle/Spline' with ID 5101 at 0x0000000012661DF0> 68 (68 points means that all the intermediate points became points)
      (last print) returns <c4d.BaseObject object called 'Circle/Circle' with ID 5181 at 0x0000000010B1E1F0>.
      Any other ideas or THE solution?
      Thx and greetings
      rownn
        On 14/12/2016 at 16:08, xxxxxxxx wrote:
        The best method that I've found is to use SendModelingCommand with Make Editable. Doesn't work in all cases, but that's your best shot if you want to maintain the original points.
          On 14/12/2016 at 16:09, xxxxxxxx wrote:
          You'll probably want to watch the progress on this thread:
          https://developers.maxon.net/forum/topic/9791/13170_getvirtualobjects-v-getcontour-for-spline-gen&PID;=52510#52510
            On 14/12/2016 at 16:16, xxxxxxxx wrote:
            Try cloning the result you get after the MakeEditable, that should keep it alive.
            """Make Editable
            Inserts the "editable" version of the selected object.
            v0.0.1
            by Donovan Keith
            from c4d import gui
            def MakeEditable(op) :
                if not op:
                op_clone = op.GetClone()
                if not op_clone:
                result_list = c4d.utils.SendModelingCommand(
                                            list = [op_clone],
                                            doc = op.GetDocument())
                if not result_list:
                result = result_list[0].GetClone()
                return result
                spline = MakeEditable(op)
                if not spline:
                doc.StartUndo()
                doc.InsertObject(spline)
                doc.AddUndo(c4d.UNDOTYPE_NEW, spline)
                doc.EndUndo()
              On 15/12/2016 at 01:29, xxxxxxxx wrote:
              Hey Donovan,
              thanks for your reply. I hope I got it, but its a bit strange.
              This seems to work.
              clone = child.GetClone()
                        list = [clone],
                        doc = op.GetMain())[0].GetClone()
              This seems to work, too. (Without cloning the result)
                        list = [clone],
              This doesnt work:
              So it seems Ive to put the clone into a varaible before calling c4d.MCOMMAND_MAKEEDITABLE.
              Thanks again and greetings
              rownn
                On 15/12/2016 at 02:12, xxxxxxxx wrote:
                Yeah, I think what's happening is that if you do .GetClone() in the function call SendModelingCommand() owns the clone. When SMC is done executing garbage collection kills the reference to the clone.
                By making the clone and assigning it to a variable, you're ensuring that it will be "needed" by the calling function and that garbage collection won't delete it prematurely.
                At least that's my best guess. I remember working through the exact same issue and it felt like voodoo as I was trying to figure out where I'd gone wrong.
                  On 15/12/2016 at 02:44, xxxxxxxx wrote:
                  Ok, cloning the result is nessesary if you wanne store the object ... makes sence.
                    On 15/12/2016 at 12:41, xxxxxxxx wrote:
                    Hi Rown, thanks for writing us.
                    With reference to your question,  I suggest to use the GetRealSpline() method once you've checked the primitive type of the input object. This method basically returns for procedural curve generator the spline data (like points and tangents).
                    If beside querying for the spline data your intent is to use the child inside the GetVirtualObjects() I suggest to experiment with GetHierarchyClone() combined with GetAndCheckHierarchyClone() as shown in the short snippet below. At the moment the GetHierarchyClone() behaves a little bit differently than how it's implemented in C++ (we're working to fix it in future) but using it combined with GetAndCheckHierarchyClone() provides a viable alternative
                    def GetVirtualObjects(self, op, hh) :
                        if op is None or hh is None:
                            return None
                        cloneDirty = False
                        clone = None
                        childDirty = -1
                        dirty = False
                        if not child:
                            return None
                        if not (child.IsInstanceOf(c4d.Ospline) or child.IsInstanceOf(c4d.Oline) or child.GetInfo()&c4d.OBJECT_SPLINE) :
                            print ("Child object doesn't belong to spline/line primitive type")
                            return None
                        realSpline = child.GetRealSpline()
                        if realSpline is not None:
                            PrintSplineData(realSpline)
                        resGHC = op.GetHierarchyClone(hh, child, c4d.HIERARCHYCLONEFLAGS_ASSPLINE)
                        if resGHC is None:
                            resGHC = op.GetAndCheckHierarchyClone(hh, child, c4d.HIERARCHYCLONEFLAGS_ASSPLINE, False)
                        if resGHC is not None:
                            cloneDirty = resGHC["dirty"]
                            clone = resGHC["clone"]
                        # it should return true only if the cloned object has been updated
                        # but it seems that it returns true even if child has not changed
                        dirty |= cloneDirty
                        # add the dirty status of the operator data
                        dirty |= op.IsDirty(c4d.DIRTYFLAGS_DATA)
                        # recursively compute the child dirty status
                        childDirty = RecursiveCheckDirty(child)
                        child.Touch()
                        # compare the dirtyness of local and member variable and accordingly update the generator's
                        # dirty status and the member variable value
                        dirty |= self._childDirty != childDirty
                        self._childDirty = childDirty
                        cache = op.GetCache()
                        if not dirty and cache is not None:
                            return cache
                        return clone
                    Best, Riccardo
                      On 01/01/2017 at 06:18, xxxxxxxx wrote:
                      Hey KnickKnack,
                      sorry for my late reply.
                      I thank you for your hint to use GetRealSpline(), but I wasn´t able to understand all intensions in your code, so I have writting the following and it works for me.
                      import os
                      import math
                      import sys
                      PLUGIN_ID = 12345557
                      class ObjektDataTest(plugins.ObjectData) :
                        def __init__(self) :
                            self.child = None
                            self.sourcePoints = []
                        def checkIsDirty(self, spline) :
                            if spline: pnts = spline.GetAllPoints()
                            else: pnts = []
                            if pnts != self.sourcePoints:
                                self.sourcePoints = pnts
                            else: return False
                        def getSplineObject(self, child) :
                            if child.CheckType(c4d.Oinstance) :
                                if child[c4d.INSTANCEOBJECT_LINK].GetType() in self.acceptedTypes: realSpline = child[c4d.INSTANCEOBJECT_LINK].GetRealSpline()
                            else: realSpline = child.GetRealSpline()
                            if realSpline: return {'splineObject': realSpline, 'dirty': self.checkIsDirty(realSpline)}
                            else: return {'splineObject': None, 'dirty': False}
                            if op is None or hh is None: return None
                            if not child:return None
                            if not child[c4d.ID_BASEOBJECT_GENERATOR_FLAG]: return None
                            if self.child != child: childNew = True
                            else: childNew = False
                            self.child = child
                            gSO = self.getSplineObject(child)
                            realSpline = gSO['splineObject']
                            if not realSpline: return None
                            if op.GetCache() == None or child.IsDirty(c4d.DIRTYFLAGS_DATA) or child.IsDirty(c4d.DIRTYFLAGS_MATRIX) or gSO['dirty'] or op.IsDirty(c4d.DIRTYFLAGS_DATA) or childNew:
                                print "DO STUFF", realSpline.GetPointCount()
                                obj = realSpline.GetClone()
                            else: obj = op.GetCache().GetClone()
                            return obj
                        icon.InitWith(os.path.join(dir, "res", "ObjektDataTest.tif"))
                        plugins.RegisterObjectPlugin(id=PLUGIN_ID, str="ObjektDataTest",
                                                    g=ObjektDataTest,
                                                    description="ObjektDataTest",
                                                    icon=icon,
                                                    info=c4d.OBJECT_GENERATOR)
                      Thx again and a happy new year!!
                      rownn
                      EDIT: Have optimized the code
