    Getting user data
    3 Posts 0 Posters 458 Views
      On 08/12/2016 at 09:26, xxxxxxxx wrote:
      Cinema 4D Version:   16
      Ok, I am lost on how to get the userdata of an object.
      I am trying to get userdata # 11 (float) and userdata #30(gradient).
      The float seems to work, but when I try to do the same for the gradient, it fails.
      The compiler tells me 'udEntry': redefinition; multiple initialization.
      Here is the code.
      Int32 gizmo;
      GeData d;
      BaseObject* c4domeObj = GetActiveDocument()->SearchObject("obj with userdata");
      if (!c4domeObj) return FALSE;
      DynamicDescription *dd = obj->GetDynamicDescription();
      if(!dd) return FALSE;
      gizmo = 11;			//brightness
      DescID udEntry(DescLevel(ID_USERDATA, DTYPE_SUBCONTAINER, 0), DescLevel(gizmo));
      obj->GetParameter(udEntry, d, DESCFLAGS_GET_0);
      GePrint("Brightness: " + String::FloatToString(d.GetFloat()));
      //get the gradient custom data
      gizmo = 30;			//gradient
      Gradient* gd = (Gradient* )d.GetCustomDataType(CUSTOMDATATYPE_GRADIENT);
      Int32 kcnt = gd->GetKnotCount();
      It feels, I do not completely understand what is going on.
      Is there not a simple routine to readthe user data for a specific number?
      -Pim
        On 09/12/2016 at 05:09, xxxxxxxx wrote:
        I solved it by looking for the name instead of the id using BrowseGetNext.
        -Pim
          On 09/12/2016 at 05:15, xxxxxxxx wrote:
          Hi Pim,
          the issue has nothing to do with userdata. It's actually as the compiler says, you defined the variable udEntry twice.
