    Add Help Info to a UI Custom Button ?
    3 Posts 0 Posters 309 Views
      On 15/11/2016 at 16:09, xxxxxxxx wrote:
      hi  guys,
      I was wondering how i can add the help info to the ui custom button that is added in a GeDialog, and it pop up like when you put your mouse over the button or plugin button and the info show up on what it do.
      helpInfo = "This Add a Sweep to your 3D Scene"     # Want this to show up when mose over it
      bc = c4d.BaseContainer()
      path = os.path.join(os.path.dirname(__file__), "res/UI_Icons", "UI_B1.png")  #The path to the image
      bc.SetFilename(GEN_BUTTON, path)  #Add this location info to the conatiner
      bc.SetLong(c4d.BITMAPBUTTON_BORDER, c4d.BORDER_NONE) #Sets the border to look like a button
      self.myBitButton=self.AddCustomGui(GEN_BUTTON, c4d.CUSTOMGUI_BITMAPBUTTON, helpInfo, c4d.BFH_CENTER | c4d.BFV_CENTER, 78, 0, bc)
      self.myBitButton.SetImage(path, True)  #Add the image to the button
      If I cannot do that , is there a way to add a Plugin  or a Plugin ID to a button or part of the the GUI layout GeDialog then.
      If any thread, tips or somewhere in the Python SDK Documentation I miss,  **any ideas, that will be appreciative guys. 🙂
        On 15/11/2016 at 18:49, xxxxxxxx wrote:
        Heya,
        I'm not sure if it's in the Python docs or not, but from the C++ documentation it's:
        bc.SetString(c4d.BITMAPBUTTON_TOOLTIP, "This button makes your dreams come true<br>And not the one where you're late for class and miss an important test")
          On 15/11/2016 at 20:16, xxxxxxxx wrote:
          Thanks Withers,
          That works 🙂 !
          bc = c4d.BaseContainer()                            ######Create a new container to store the button image
          helpInfo = "Thanks Whithers\nAnd You have a great and safe day."
          bc.SetString(c4d.BITMAPBUTTON_TOOLTIP, helpInfo)
          bc.SetBool(c4d.BITMAPBUTTON_BUTTON, True)
          self.myBitButton=self.AddCustomGui(GEN_BUTTON, c4d.CUSTOMGUI_BITMAPBUTTON, "", c4d.BFH_CENTER | c4d.BFV_CENTER, 78, 0, bc)
          self.myBitButton.SetImage(path, False)  #Add the image to the button
          THANKS again,
          AP Ashton
