    Merge scene from user library
    7 Posts 0 Posters 610 Views
      On 14/11/2016 at 06:27, xxxxxxxx wrote:
      I have defined my own library (content browser) and added some scenes to it.
      Now I am trying to merge these scenes using following code:
      import c4d, os
      from c4d import gui
          userLib = c4d.storage.GeGetStartupWritePath()
          fn = os.path.join(userLib, "library", "browser", "own stuff.lib4d", "spheres test scenes.c4d")
          print "fn: ", fn
          print c4d.documents.MergeDocument(doc,fn, 0)
          print "Done."
      The filename given for the merge seems correct:
      fn:  C:\Users\Pim\AppData\Roaming\MAXON\CINEMA 4D R17_8DE13DAD\library\browser\own stuff.lib4d\spheres test scenes.c4d
      The MergeDocument always return false, what am I doing wrong?
      -Pim
        On 14/11/2016 at 09:28, xxxxxxxx wrote:
        The .lib4d is a file obviously, so the path you create is not valid for the filesystem. For library content,
        Cinema uses a URL with the preset:// scheme. I may be mistaken, the path you want to use is likely
        something similar to
        preset://own stuff/spheres test scenes.c4d
        Of course this can only be handled and be interpreted correctly by C4D SDK functions/classes.
        -Niklas
          On 15/11/2016 at 00:46, xxxxxxxx wrote:
          Sorry still not working.
          Here my code and console output:
          import c4d, os
          from c4d import gui
              #fn = os.path.join(userLib, "library", "browser", "own stuff.lib4d", "spheres test scenes.c4d")
              fn = "preset://own stuff/spheres test scenes.c4d"
              print "fn: ", fn
              print "Done."
          #Console output:
          fn:  preset://own stuff/spheres test scenes.c4d/
          False
          Done.
          I also copied the lib4d file to the main c4d library folder: C:\Program Files\MAXON\CINEMA 4D R17\library\browser, but that did not help.
          What do you mean with "Of course this can only be handled and be interpreted correctly by C4D SDK functions/classes.". Can I not merge documents using c4d.documents.MergeDocument(doc,fn, 0)?
          -Pim
            On 15/11/2016 at 03:08, xxxxxxxx wrote:
            Hi Pim,
            basically Niklas was already right. I think, the only thing you are missing is to correctly address the preset library correctly.
            For example it looks like so, if you want to load something from the Prime library:
            fn = "preset://prime.lib4d/Example Scenes/Ambient Occlusion/Keys.c4d"
              On 15/11/2016 at 04:48, xxxxxxxx wrote:
              Ok, it is now working, after adding a sub folder in my own user defined content browser.
              fn = "preset://own stuff.lib4d/water 01.c4d"                               NOT working
                  fn = "preset://own stuff.lib4d/testFolder/water 01.c4d"        + subfolder - Working!!!
                On 15/11/2016 at 05:28, xxxxxxxx wrote:
                Hi Pim,
                I'm sorry, but I can't reproduce the need for a sub-folder.
                I created my own preset library named "test" and copied a scene "platonic.c4d" into it.
                fn = "preset://test.lib4d/platonic.c4d"
                c4d.documents.LoadFile(fn)
                This worked just fine for me.
                  On 15/11/2016 at 07:40, xxxxxxxx wrote:
                  Hi Andreas,
                  Yes, you are correct.
                  I do not what changed (perhaps too focused), but your solution is working.
                  No sub folder needed.
                  Thanks, Pim
