    Send Message to Weight Tag
    3 Posts 0 Posters 334 Views
      On 05/11/2016 at 18:35, xxxxxxxx wrote:
      Hello Forum,
      I'm writing a script to resize a rig and would like to send c4d.ID_CA_WEIGHT_TAG_SET to a weigh tag.
      I found this C++ link:
      https://developers.maxon.net/forum/topic/5222/5217_reset-bind-pose&KW=set+bind+pose&PID=21410#21410
      This does not work:
      tag.Message(c4d.MSG_DESCRIPTION_COMMAND, c4d.DescID(c4d.DescLevel(c4d.ID_CA_WEIGHT_TAG_SET)))
      Python Error:
        File "'active-layer.pypv'", line 515, in CoreMessage
        File "'active-layer.pypv'", line 176, in ActiveLayerIsOn
      TypeError: C4DAtom.Message expected dict, not c4d.DescID
      So I made a guess and this seems to work:
      tag = op.GetTag(c4d.Tweights)
      data = dict()
      data['id'] = c4d.ID_CA_WEIGHT_TAG_SET
      tag.Message(c4d.MSG_DESCRIPTION_COMMAND, data)
      Is this the correct way to Message() a C4DAtom with a script?
      Thank you,
      Joe Buck
        On 07/11/2016 at 02:38, xxxxxxxx wrote:
        Hi Joe,
        there's nothing wrong with your solution.
        A bit shorter, the same could be achieved by using CallButton(), but there's really no difference otherwise.
          On 07/11/2016 at 07:00, xxxxxxxx wrote:
          Thanks Andreas.
