    Render sequence from viewport
    3 Posts 0 Posters 330 Views
      On 30/10/2016 at 14:53, xxxxxxxx wrote:
      Hi guys! I have I think a simple task.
      Just what I want is to render sequence of frames form viewport. Script should call render the current frame and then go to next frame and then call the render current frame again and ect. I started with something but my problem is how to go back from thread to main function and call render again?
      import os,time, thread
      onRender = False
      def isRendering(time,os) :
          while c4d.CheckIsRunning ( c4d.CHECKISRUNNING_EXTERNALRENDERING ) :
              time.sleep(1)
              onRender = True
              print (onRender)
          onRender = False
          print (onRender)
          thread.exit()
      # here I need to call render current frame
          c4d.CallCommand(12099) # Render Current Frame
          thread.start_new(isRendering,(time,os))
          c4d.CallCommand(12414) # Go to Next Frame
          print ("next frame")
        On 31/10/2016 at 09:16, xxxxxxxx wrote:
        Hi Alex,
        In general we do not recommend to use threads in scripts (i.e. started from the Script Manager).
        Rather I'd implement a CommandData plugin (just a few more lines compared to your script, you'd use this to start the rendering) and a MessageData plugin (to receive a "done" message, see below).
        Instead of plain Python threads we recommend C4D's own C4DThread.
        Instead of using CallCommand() I'd recommend to use directly RenderDocument() in a thread (another example on how to use RenderDocument() is in tokensystem_render.py).
        When you take a look at the code snippets in documentation or in the example, you will see, that setting up customized RenderData is quite easy. So maybe you need not render every single frame separately, but could instead simply set up a frame range in RenderData and do one RenderDocument for all wanted frames.
        And then, when your thread is done with rendering you can use SpecialEventAdd() to send a CoreMessage to the above mentioned MessageData plugin, where you receive it in CoreMessage() and are back in the main thread.
        Some more information on CoreMessages can be found in the latest C++ docs: Custom Messages
        Also in C++ docs: RenderData Manual and BaseDocument - Render
        Just an idea and of course only one way of doing it.
          On 01/11/2016 at 11:41, xxxxxxxx wrote:
          Thank you, Andreas, I don't know if I can use your advise because I have no enough knowledge in this field, but I try.
