    Handling MessageData.GetTimer() event
    10 Posts 0 Posters 1.9k Views
      On 15/10/2016 at 17:29, xxxxxxxx wrote:
      Hi everyone.
      I'm trying to create timer that runs a function twice a second.
      Here's the code of my plugin:
      from c4d import plugins
      PLUGIN_ID=123454321
      class MyMsg(c4d.plugins.MessageData) :
        def GetTimer(self) :
            return 500
      def CoreMessage(self, id, bc) :
            if id==PLUGIN_ID:
                MyFunction()
      def MyFunction() :
        print "tick"
      if __name__=="__main__":
        plugins.RegisterMessagePlugin(PLUGIN_ID, "TestPlugin", 0, MyMsg())
      I can't figure out how to create and handle timer event. Is it possible? What am I doing wrong.
      Would appreciate any help.
      Have a nice day.
        On 16/10/2016 at 07:15, xxxxxxxx wrote:
        Try it like this
        from c4d import documents, plugins
        PLUGIN_ID = 1000000
        class MyMessage(plugins.MessageData) :
          def __init__ (self) :
              self.object = None
              return 500
              if id == c4d.MSG_TIMER:
                  print "Timer Executed"  #<---Put the call to your function here
          plugins.RegisterMessagePlugin(id=PLUGIN_ID, str="Message Plugin", info=c4d.PLUGINFLAG_SMALLNODE, dat=MyMessage())
          On 16/10/2016 at 09:41, xxxxxxxx wrote:
          Thanks a lot, Scott, but there is 1 problem with the code you gave me: Event fires up about 20 times per second, not twice.  Should I check the time manually, or what?
          *There's not a single word about "c4d.MSG_TIMER" in Maxon's python documentation. ConfusedConfusedConfused
            On 16/10/2016 at 10:09, xxxxxxxx wrote:
            The GeTimer() executes in milliseconds.
            Change return 500 to whatever value you want.
            Try something like 2000 for starters.
            There's an example of this in the C++ docs.
            Sometimes the answer to a Python question can be found in there.
              On 16/10/2016 at 10:18, xxxxxxxx wrote:
              Scott, I'm afraid you didn't understand me. Please pardon my english - it's not my native language. 🙂
              Let me repeat myself: YOUR code (with "return 500" statement) fires up about twenty times per second. Is it bug?
              *R17.053
                On 16/10/2016 at 10:30, xxxxxxxx wrote:
                Hopefully this will be clearer.
                PLUGIN_ID = 1000000
                      self.object = None
                      timerValue = 2000    #<--- Change this value to change how long to wait between executions
                      return timerValue
                  On 16/10/2016 at 10:44, xxxxxxxx wrote:
                  "Lost in translation" as is.:)
                  This code My target function   fires up 20 times per second with no matter of return value in GetTimer() method:
                        return 500
                  and
                        return 5000
                  and even
                        return 50000
                  are giving the same result. Looks like a bug to me.
                  Don't you have such a problem on your PC?
                    On 16/10/2016 at 11:04, xxxxxxxx wrote:
                    Working properly for me in R13.
                    Increasing the timer value makes it wait longer between executions as expected.
                    Are you running this in the script manager?
                    The code I posted is a plugin. The code should be saved in a .pyp file and then place in the plugins folder.
                      On 16/10/2016 at 11:12, xxxxxxxx wrote:
                      LOL. Of course I'm running this code as a plugin. I think that it's a little bug in R17 and combining this code with the c4d.GeGetTimer() gonna give me the desired result.
                      Anyway thanks a lot - you really helped me very much.
                      UPD: I've sent a bug report about this problem.
                        On 17/10/2016 at 07:40, xxxxxxxx wrote:
                        there's indeed a bug in the Python layer.
                        See related thread: here
