    Enable / Disable GUI from res file
    5 Posts 0 Posters 694 Views
      On 19/09/2016 at 00:16, xxxxxxxx wrote:
      Hi All,
      I'm working on a plugin where i would like to enable/disable a piece of the gui generated by the .res file.
      Is there a way to do this?
      Thanx in advance
        On 19/09/2016 at 06:13, xxxxxxxx wrote:
        From within a resource file this is not possible.
        Via code it is possible, but it depends whether you are working with a description or a dialog.
        For a description resource of a NodeData (and derived) or ToolData based plugin you need to implement GetDEnabling(). Check the Py-DoubleCircle or Py-DynamicParametersObject examples to see GetDEnabling() in action.
        In a GeDialog you use Enable(). See the Py-TextureBaker example.
          On 19/09/2016 at 09:09, xxxxxxxx wrote:
          Thanx Andreas,
          This is a real though one and if i should believe the forums i'm not the only one struggling with this problem :D.
          It is used in a python ObjectPlugin
          This is my code so far
          def GetDEnabling(self, node, id, t_data, flags, itemdesc) :
                data = node.GetDataInstance()
                  if data is None:
                  if data.GetBool(ONOFF_ENABLED) :
          My question is what should come next to gray out the item MY_SUBBOX
            On 19/09/2016 at 10:20, xxxxxxxx wrote:
            I know it's a tiny bit confusing, but did you look at the DoubleCircle example?
            In your case
            	if id[0].id == MY_SUBBOX:
            		return False
            would disable MY_SUBBOX if ONOFF_ENABLED, assuming you assigned its id properly.  I also gave you an example when you posted on the other cafe...
              On 20/09/2016 at 01:10, xxxxxxxx wrote:
              I saw your post on the other forum. I know it was the same question but this gives me the possibility to call you a hero twice 😉
