    DESCFLAGS_SET parameters and access violation
    3 Posts 0 Posters 327 Views
      On 16/09/2016 at 01:32, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Hello.
      I have a scenario in which a tag data plugin is applied to an object.
      I get access violation when I try to copy a filename parameter from the TagData to the object in Read method of that TagData.
      Here is the code:
      GeData from_data;
      tag->GetParameter(FILENAME_PARAM, from_data, DESCFLAGS_GET_0);
      object->SetParameter(LIGHT_PHOTOMETRIC_FILE, from_data, DESCFLAGS_SET_0);
      The object and the tag belong to an Xref object.
      Nevertheless, when I use DESCFLAGS_SET_PARAM_SET instead of DESCFLAGS_SET_0, I don't get the crash.
      The object I'm referring to is a light object and the filename parameter I try to set is the photometric one.
      I have seen this:
      https://developers.maxon.net/forum/topic/9440/12650_trying-to-changeupdate-ies-filename-in-lightsourc&KW=DESCFLAGS_SET_0+DESCFLAGS_SET\_&PID=50020#50020
      Could you please give me some hints regarding the DESCFLAGS_SET values and when to use them as parameters ? (Any documentation or example would be much appreciated).
      I have used DESCFLAGS_SET_0 and DESCFLAGS_GET_0 almost everywhere and I didn't have a problem.
      Thank you.
        On 16/09/2016 at 13:23, xxxxxxxx wrote:
        Edit: I got all the information i needed regarding the GetDParameter and SetDParameter from https://developers.maxon.net/forum/topic/9715/13064_getdatainstance-and-getparameter-in-tagdata-read
        Now what's left to solve is why I get the access violation on light_object.SetParameters(...).
        The issue appears only when the object belongs to a separate project file and i retrieve it via Xref.
        thnx again.
          On 19/09/2016 at 08:51, xxxxxxxx wrote:
          so far I could not reproduce an access violation or any other error based on your description. Please notice that by default a Xref prevents anyone from changing the imported objects, including any tags. So your tag might only be able to change the parameter when you make parameters editable (see documentation).
