    GetDataInstance and GetParameter in TagData Read
    7 Posts 0 Posters 890 Views
      On 16/09/2016 at 00:47, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Hello.
      I have a filename parameter, which I try to retrieve in Read method (TagData plugin).
      Here is the code using GetDataInstance and GetParameter
      //1
      BaseContainer* tag_data = tag->GetDataInstance();
      String filename = tag_data->GetFilename(FILENAME_PARAM).GetString();
      //2
      GeData ge_data;
      tag->GetParameter(FILENAME_PARAM, ge_data, DESCFLAGS_GET_PARAM_GET);
      String filename = ge_data.GetFilename().GetString();
      The first filename gets the value correctly, while the second filename string appears empty.
      Why GetParameter doesn't return the value correctly ?
      Thank you.
        On 16/09/2016 at 02:07, xxxxxxxx wrote:
        you are using DESCFLAGS_GET_PARAM_GET, which is the flag for saying, the parameter got read successfully. Can you please try, if the problem persists, if you use DESCFLAGS_GET_0 instead?
          On 16/09/2016 at 05:44, xxxxxxxx wrote:
          Hello.
          Using DESCFLAGS_GET_0 returns the correct value. So I assume that whenever I want to read a parameter, I have to use DESCFLAGS_GET_0 right ?
          When am I supposed to use DESCFLAGS_GET_PARAM_GET ?
          Thank you for your time.
            On 16/09/2016 at 05:50, xxxxxxxx wrote:
            DESCFLAGS_GET_PARAM_GET is used inside GetDParameter() to mark the successful retrieval of the parameter. You don't pass it into GetParameter().
              On 16/09/2016 at 06:16, xxxxxxxx wrote:
              Hello.
              I didn't know that. I assume SET_PARAM_SET does the same right (in SetDParameter)?
              thnx.
                On 16/09/2016 at 08:56, xxxxxxxx wrote:
                Yes. Sorry, I got disturbed, while posting. I actually wanted to mention this in my post.
                  On 16/09/2016 at 09:01, xxxxxxxx wrote:
                  Even worse, I forgot to post the links to our documentation.
                  Manuals on GetDParameter() and SetDParameter() and here the API reference: GetDParameter() and SetDParameter().
