    Message Data doesn't receive message
    SDK Help
    0
    • H
      On 24/08/2016 at 04:43, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Hello.
      I have a MessageData plugin and in its CoreMessage method i check for EVMSG_DOCUMENTRECALCULATED. Then I move the main camera in the viewport, but the event never reaches there. Message data receives EVMSG_DOCUMENTRECALCULATED events but not the camera one. Nevertheless, if the CoreMessage is implemented in a GeDialog, it receives the camera events correctly.
      What's wrong with the message data ? I register the plugin using RegisterMessagePlugin.
      Also, does the CoreMessage return value do anything ? The API says it doesn't.
      Thank you for your time.
      • H
        On 24/08/2016 at 05:03, xxxxxxxx wrote:
        Hello.
        Correction: MessageData doesn't receive EVMSG_ASYNCEDITORMOVE.
        That's the event I want to catch.
        thnx.
        • H
          On 25/08/2016 at 02:28, xxxxxxxx wrote:
          EVMSG_ASYNCEDITORMOVE is only send to dialogs. Sorry.
          We are aware that our documentation is sub-optimal on this topic. It is on our list, but we will need time to thoroughly improve the docs on this matter.
          • H
            On 25/08/2016 at 03:04, xxxxxxxx wrote:
            Hello.
            No problem for the docs.
            So, if I want to catch EVMSG_ASYNCEDITORMOVE and redirect them to a MessageData, I have to do it using only a dialog right ?
            Thank you.
            • H
              On 29/08/2016 at 08:48, xxxxxxxx wrote:
              Basically this should work, yes.
