    Extending Python - Pass Variable Parameter?
    SDK Help
    0
    • H
      On 09/08/2016 at 16:13, xxxxxxxx wrote:
      Cinema 4D Version:   R13+
      Language(s) :     C++  ;   PYTHON  ;
      Howdy,
      Is it possible to create a python extension function that takes an integer for the first parameter, and then a variable parameter for a second parameter, like I can do with a coffee extension function?
      For instance if I want the first parameter to be an ID, and then the second parameter to be either a bool, integer or float. Is that possible?
      Adios
      Cactus Dan
      • H
        On 09/08/2016 at 18:16, xxxxxxxx wrote:
        Howdy,
        OK, never mind. I took an educated guess and it worked perfectly:
        LONG id;
        GeData gdata;
        const CHAR *kwlist[] = {"integer", "gedata", NULL};
        if(!pylib.ParseTupleAndKeywords(args, keywords, "iG", kwlist, &id, &gdata)) return pylib.ReturnPyFALSE();
        if(gdata.GetType() != DA_LONG && gdata.GetType() != DA_REAL) return pylib.ReturnPyFALSE();
        The last line checks the type, so the function only accepts a bool, int or float (a bool is actually an int). 😉
        Adios,
        Cactus Dan
        • H
          On 10/08/2016 at 02:31, xxxxxxxx wrote:
          Yes, using a GeData is the way to go in Python to parse a parameter that can be of various types.
          • H
            On 10/08/2016 at 05:45, xxxxxxxx wrote:
            Howdy,
            Well, the educated guess was mainly in the use of the string "gedata". I sort of knew that a GeData was the way to go.
            That's why I asked in the other thread if you could post a complete list of parameters for the different types. 😉
            Adios,
            Cactus Dan
