    Current Active Tab from TabGroup
    3 Posts 0 Posters 364 Views
      On 05/08/2016 at 16:03, xxxxxxxx wrote:
      Cinema 4D Version:   17
      Platform:    Mac  ;  Mac OSX  ;
      Couldn't find the answer to this on the forums or in the SDK examples.
      I have extended the GeDialog class and added a TabGroup to my dialog. Is there a way to figure out what the current active tab is from the Command method? Partial code snippet below:
      #define ID_AOVS_TABS 11021114
      #define ID_AOVS_TABS_STANDARD 11021115
      #define ID_AOVS_TABS_LPE 11021116
      #define ID_AOVS_STANDARD_LIST 11030000
      #define ID_AOVS_LPE_LIST 11031000
      #define ID_AOVS_LISTVIEW 11021120
      #define ID_AOVS_CHANNELS_LISTVIEW 11021122
      #define ID_AOVS_BUTTON_ADDCHANNEL 11021124
      class AOVSDialog: public GeDialog
      private:
          Int32 _lastcoremsg_change;
          AOVSDialog();
          virtual ~AOVSDialog(void);
          virtual Bool CreateLayout();
          virtual Bool Command(Int32 id,const BaseContainer & msg );
          virtual Bool CoreMessage(Int32 id, const BaseContainer &msg);
      private:
          SimpleListView m_aovListView;
          SimpleListView m_channelListView;
          SimpleListView m_standardListView;
          SimpleListView m_lpeListView;
          Int32 m_activeTab;
      AOVSDialog::AOVSDialog(void)
          _lastcoremsg_change = NOTOK;
      Bool AOVSDialog::CreateLayout()
          SetTitle("Example");
          GroupBegin(1000, BFH_SCALEFIT | BFV_FIT, 3, 0, "", BFV_BORDERGROUP_FOLD_OPEN, 400, 100);
          GroupBorderSpace(10, 10, 10, 10);
          TabGroupBegin(ID_AOVS_TABS, BFH_SCALEFIT | BFV_SCALEFIT);
          GroupBegin(ID_AOVS_TABS_STANDARD, BFH_SCALEFIT | BFV_SCALEFIT, 1, 0, "Standard", BFV_BORDERGROUP_FOLD_OPEN, 400, 100);
          AddListView(ID_AOVS_STANDARD_LIST, BFH_SCALEFIT | BFV_SCALEFIT );
          m_standardListView.AttachListView(this, ID_AOVS_STANDARD_LIST);
          layout.SetInt32('name', LV_COLUMN_TEXT);
          m_standardListView.SetLayout(1, layout);
          m_standardListView.SetProperty(SLV_MULTIPLESELECTION, 1);
          for (size_t i = 0; i < standardAOVS.size(); ++i)
      	// add stuff to list
          GroupEnd();
          GroupBegin(ID_AOVS_TABS_LPE, BFH_SCALEFIT | BFV_SCALEFIT, 1, 0, "LPE", BFV_BORDERGROUP_FOLD_OPEN, 400, 100);
          AddListView(ID_AOVS_LPE_LIST, BFH_SCALEFIT | BFV_SCALEFIT );
          m_lpeListView.AttachListView(this, ID_AOVS_LPE_LIST);
          m_lpeListView.SetLayout(1, layout);
          m_lpeListView.SetProperty(SLV_MULTIPLESELECTION, 1);
          for (size_t i = 0; i < lpeAOVS.size(); ++i)
          GroupEnd();
          GroupEnd(); // TabGroupBegin
          m_activeTab = ID_AOVS_STANDARD_LIST;
          AddButton(ID_AOVS_BUTTON_ADDCHANNEL, BFH_LEFT | BFV_CENTER, 0, 10, "Add Channel(s)");
          GroupEnd();
      Bool AOVSDialog::Command(Int32 id, const BaseContainer & msg)
          switch(id)
              case (ID_AOVS_TABS) :
      	   // set m_activeTab...how?
                  break;
      Thanks!
      Ian
        On 05/08/2016 at 16:17, xxxxxxxx wrote:
        Each tab has an ID and you can get the ID of the active tab with GeDialog::GetInt32().
          On 08/08/2016 at 09:02, xxxxxxxx wrote:
          Awesome! That worked for me.
          Thanks!
          Ian
