    How to Determine if an Object Supports Effectors?
    3 Posts 0 Posters 291 Views
      On 01/08/2016 at 11:37, xxxxxxxx wrote:
      What is the best practice to check to see if an object is a MoGraph object and supports effectors? I'm currently manually building a list of object ID's and checking against that.
      def is_cloner(obj) :
          CLONER_IDS = [
              1018544, # Cloner
              1018545, # Matrix
              1018791, # Fracture
              1018957, # MoInstance
              1019268, # MoText
              1018655, # Tracer
              440000054 # MoSpline
          if obj.GetType() in CLONER_IDS:
          return False
      This works fine until a new cloner object is introduced (like the new Voronoi Fracture), at which point my plugin doesn't behave as expected and I have to add the new ID and push out an update to all users. Is there a method in the mograph module for checking this?
      Donovan
        On 02/08/2016 at 02:26, xxxxxxxx wrote:
        Hi Donovan,
        all these objects are an instance of Obasemogen. Just note, this is also true for the PolyFX, but as it takes effectors as well, it's probably even a desired side effect.
          On 02/08/2016 at 14:38, xxxxxxxx wrote:
          Perfect. Thank you!
          """Is it a MoGraph Generator?
          from c4d import gui
              if not op:
              if op.IsInstanceOf(c4d.Obasemogen) :
                  print op.GetName() + " is a MoGraph Generator!"
                  print op.GetName() + "is not a MoGraph Generator."
          It seems like "Obasemogen" isn't documented in the Python SDK, so I'd suggest adding it.
          Thanks!
          Donovan
