    How to access display tag data?
    4 Posts 0 Posters 632 Views
      On 27/02/2003 at 03:28, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      isn't it possible to change data of a display tag?
               tag = BaseTag::Alloc(Tdisplay);
               if (tag)
                op->InsertTag(tag, NULL);
                cData = tag->GetDataInstance();
                cData->SetBool(DISPLAYTAG_AFFECT_DISPLAYMODE, TRUE);
                cData->SetLong(DISPLAYTAG_DISPLAYMODE, DISPLAYTAG_DISPLAYMODE_WIREFRAME);
      This code will insert the tag, but container data is not affected!?
      To verify the ID values, I tried this:
            BaseTag *tag = op->GetTag(Tdisplay);
            if (tag)
             BaseContainer *cData = tag->GetDataInstance();
             LONG i;
             GePrint("Searching ID...");
             for (i=1000; i<100000; i++)
              if (cData->GetLong(i) == DISPLAYTAG_DISPLAYMODE_WIREFRAME)
               GePrint("ID:" + LongToString(i));
      Nothing. I can change any value using the gui of the tag without any effect in the container data.
      What's wrong?
      Analogous to Tphong and SetPhong(...), I looked for a method like "SetDisplay(...)"; without any success.
      Klaus Heyne
        On 27/02/2003 at 06:03, xxxxxxxx wrote:
        please search this forum with a corresponding value. There was already a thread that solved this problem.
          On 28/02/2003 at 10:12, xxxxxxxx wrote:
          Thanks for the hint. But the thread you mean, handles with coffee and didn't solve the problem.
          So, again a code snippet from the execute function of a plugin tag, assigned to the object, that also has the display tag:
                BaseTag *dTag = op->GetTag(Tdisplay);
                if (dTag)
                 BaseContainer *dData = dTag->GetDataInstance();
                 dData->SetBool(DISPLAYTAG_AFFECT_DISPLAYMODE, TRUE);
                 dData->SetLong(DISPLAYTAG_DISPLAYMODE, DISPLAYTAG_DISPLAYMODE_WIREFRAME);
                 dTag->Message(MSG_UPDATE);
          The debugger does not show the name of the display tag!? Should it?
          Is there something wrong with GetDataInstance?
          Klaus Heyne
            On 28/02/2003 at 10:21, xxxxxxxx wrote:
            sorry. My fault. Should have looked bette. HAven´t noticed you are working with C++.
            Yes, GetDataInstance is sometimes not possible (don´t ask my why. There must be a reason but I don´t know it). Use GetData to get the BaseContainer and use SetData after changing properties. This will work for the Display Tag (had the same problem some time ago).
            Best
            Samir
