    Messages and MenuPlugins
    SDK Help
    0
    • H
      On 26/02/2003 at 18:46, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Is it possible to send a message to a menu plugin from another? (How do I do this?) If so, is it then possible for the menuplugin to store the information in a basecontainer till it's called?
      • H
        On 26/02/2003 at 23:16, xxxxxxxx wrote:
        The easiest way is to implement both menu plugins in the same .cof file. Then they can share the same global variable.
        Otherwise you can experiment with a message plugin in each .cof file that also shares a global variable with its menu plugin.
        • H
          On 27/02/2003 at 20:28, xxxxxxxx wrote:
          ok thanks, yeah in the end i used the both plugins in the same .cof file as it was so much simpler for what i was doing.
