    calling CustomDataTypeClass::Calculate() [SOLVED]
    SDK Help
    0
    • H
      On 27/07/2016 at 03:40, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Hi! I'm trying to interpolate between two GeData values. But when I call CustomDataTypeClass::Calculate(),
      it always gives me GV_CALC_ERR_UNDEFINED . Does someone know what I'm doing wrong?
      Thanks a lot in advance,
      -Niklas
      GeData InterpolateValues(GeData const& left, GeData const& right, BaseList2D* node, Float w) {
        Int32 const type = left.GetType();
        if (type != right.GetType()) return left;
        // Load the CustomDataTypeClass plugin for this datatype.
        CUSTOMDATATYPEPLUGIN* plug = FindCustomDataTypePlugin(left.GetType());
        if (!plug) return left;
        auto data = static_cast<CustomDataTypeClass*>(plug->adr);
        if (!data) return left;
        GeData res = left;
        GvError err = (data->*plug->Calculate)(
          GV_CALC_MIX,
          left.GetCustomDataType(type),
          right.GetCustomDataType(type),
          res.GetCustomDataType(type),
          w);
        if (err != GV_IO_ERR_NONE) {
          // Always gets here with err == GV_CALC_ERR_UNDEFINED
          GePrint("Oh Noes! " + String::IntToString(err));
        return res;
              // Calling example
      	GeData l(10);
      	GeData r(50);
      	GeData res = InterpolateValues(l, r, nullptr, 0.5);
      	Int32 val = res.GetInt32();
      • H
        On 28/07/2016 at 08:22, xxxxxxxx wrote:
        Hi Niklas,
        I'm terribly sorry, I haven't found as much time to investigate it, as I had planned and wished.
        Just wanted to let you know, I'm on it.
        What I found so far: Your Calculate() call ends up in the "base implementation" of that function, which does nothing more than returning GV_CALC_ERR_UNDEFINED. So actually under the given circumstances, the result is actually correct 😉
        I'll continue with this tomorrow.
        • H
          On 29/07/2016 at 08:58, xxxxxxxx wrote:
          Hi Niklas,
          the reason is quite simple: Only very few custom data types implement Calculate(). From the public ones, SplineData is actually the only one (and even this implements only GV_CALC_CLR, GV_CALC_ADD and GV_CALC_MIX).
          So actually your example is correct, but it works only on data types that implemented Calculate()... SplineData that is. 😊
          • H
            On 29/07/2016 at 10:51, xxxxxxxx wrote:
            Thank you for your time and effort, Andreas. 🙂 Originally I didn't expect FindCustomDataTypePlugin()
            to actually return not-null for any of the standard datatypes (LONG, REAL, etc.), but since it did, I
            expected it to be implemented for these types as well.
            Anyway, now that I know I just do some special handling for the datatypes that I want to support
            proper interpolation for, and eventually use the CustomDataTypePlugin for any ID that I don't know
            or don't handle.
            Thanks again!
            Niklas
