    IDs and user resources
    7 Posts 0 Posters 990 Views
      On 26/02/2003 at 05:04, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      How are the IDs of GUI elements assigned or obtained? for example using the UserDialog class:
      MyDialog::CreateLayout()
      SetTitle("My Dialog");
      AddGroupBeginV(100010, 0, 1, "", 0);
      AddGroupSpace(4, 4);
      AddGroupBorderSpace(4, 4, 4, 4);
          AddStaticText(100011, 0, 0, 0, "Hello World!", 0);
      AddGroupEnd();
      AddDlgGroup(OK + CANCEL);
      are the IDs for AddGroupBegin = 1000010 or AddStaticText = 100010 listed somewhere or can I use my own values?
        On 26/02/2003 at 11:04, xxxxxxxx wrote:
        You can use your own values or assign them to a name in a dialog resource file and obtain them using GeLoadString() (of course, after having established resources).
        Robert
          On 26/02/2003 at 13:10, xxxxxxxx wrote:
          The best way is to use constants in the c4d_symbols.h file. See the examples.
            On 26/02/2003 at 21:32, xxxxxxxx wrote:
            Aha, and it does´nt matter if I´m using the symbols in c4d_symbols.h in COFFEE and not C++?
            thank you very much Robert and Mikael
              On 26/02/2003 at 23:18, xxxxxxxx wrote:
              No, c4d_symbols.h is used by both. (You have to include it in the file though with #include "c4d_symbols.h" in C++ and include "c4d_symbols.h" in C.O.F.F.E.E.)
                On 27/02/2003 at 05:13, xxxxxxxx wrote:
                Sorry to be a bore Mikael; I just downloaded the c4d_symbols.h, there were absolutely no IDs in the file(in both the 6 and 7 versions). Where can I donload this file with all the IDs listed? Or maybe I was misunderstood?
                Example:
                using the AddGroubBeginV() method, the first parameter is an ID, "100010". I´d like to know where these IDs are derived from.
                  On 27/02/2003 at 13:10, xxxxxxxx wrote:
                  Aargh, major confusion... 🙂
                  c4d_symbols.h is a file you write yourself, not some file you can download and use. Please see these pages from the documentation for a run-down on the various resource files: <[URL-REMOVED]#directory>, <[URL-REMOVED]>
                  Otoh, as I read your questions again, it seems you already visited the docs and the questions is something else. Those 100010 IDs are just hard coded instead of put in c4d_symbols.h, to create a self-contained example. (All IDs above 10000 are allowed.)
                  I recommend the resource method shown in the second of the two links above, under "Layout files".
