    BaseSort member variable?
    4 Posts 0 Posters 471 Views
      On 14/07/2016 at 12:06, xxxxxxxx wrote:
      Cinema 4D Version:   17
      I'm looking for a way to implement a variable sorting crtiteria in my BaseSort class, but I'm not getting it to work. I just want to sort an array with vectors using a tolerance value (eps) :
      class SortVector : public maxon::BaseSort <SortVector>
           static Bool LessThan(Vector a, Vector b)
                if (a.z < b.z - eps) return true;
                if (a.z > b.z + eps) return false;
                return (a.x < b.x);
           SortVector(Float d)
                eps = d;
           static Float eps;
      maxon::BaseArray<Vector> points;
      //... filling the array ...
      SortVector sort(10);
      sort.Sort(points);
      I want to start the sorting using the tolerance value, but the compiler gives me an unsolved symbol "eps" error because of the static declaration. But I can't omit static, because LessThan wouldn't know "eps". And finally I can't omit static for LessThan().
      It happens frequently, that I need additional variable parameters for sorting. How is the provided way to do this?
      Thanks of any help.
        On 14/07/2016 at 17:08, xxxxxxxx wrote:
        Did you forget to add the definition of SortVector::eps also in your actual code? Something like this in a
        translation unit (.cpp file).
        Float SortVector::eps = 1.0e-7;  // just an example value
          On 15/07/2016 at 01:45, xxxxxxxx wrote:
          You only have the declaration of the static member but you also need to give it a definition (i.e. what Niklas provided) to actually make it exist.
            On 15/07/2016 at 03:21, xxxxxxxx wrote:
            Thanks. Have to read a chapter about static stuff I guess.
