    How to expose an object function done in C++
    19 Posts 0 Posters 5.8k Views
      On 29/07/2016 at 02:37, xxxxxxxx wrote:
      OK, I got the passing a BaseList as a prameter with the "G" format, but suppose I want to pass both a BaseList and an interger or real in the same function? How would that be formatted?
      Like the argument parsing in the function example extendpyapi_PassParameters() I posted above, concatenate the characters for each parameter.
      For instance:
      GeData data;
      Int32 integer = 0;
      Float real = 0.0f;
      const Char *kwlist[] = {"baselist", "integer", "real", nullptr};
      if (!pylib.ParseTupleAndKeywords(args, keywords, "Gif", kwlist, &data, &integer, &real))
          return nullptr;
        On 29/07/2016 at 04:53, xxxxxxxx wrote:
        Howdy,
        DOH! It's the strings that always throw me off when they're used for anything other than printing.
        But I get it now:
        "$" = string format
        "i" = integer format
        "f" = float format
        "G" = GeData format
        Possibly if the example had the float first like "$fi" then I might have been able to figure that out. But, with it the other way around, no matter how many times I looked at it, I still saw the word "if", and got confused. 😊
        Thanks for the clarification.
        Adios,
        Cactus Dan
          On 29/07/2016 at 05:53, xxxxxxxx wrote:
          You're welcome 🙂
          "C" can also be used to parse BaseContainer* too (note only pointer to BaseContainer, initialize with nullptr before calling ParseTupleAndKeywords()).
            On 29/07/2016 at 06:07, xxxxxxxx wrote:
            Howdy,
            Thanks. Is there a complete list of formatting letters that you could post?
            Also, is there a way to add global symbols in python like in coffee, and if so, can you post an example?
            Adios,
            Cactus Dan
              On 26/04/2017 at 00:05, xxxxxxxx wrote:
              I know this is a bit older topic but the last question from Cactus Dan was not answered and I also need it. Especially I need to transfer BaseObject to and from python script.
              So again, we just need a table of all formatting letters and types that Cinema python binding API uses.
              Just for completeness, python build-in formatting letters seems to work and are available here: https://docs.python.org/2.7/c-api/arg.html?highlight=parsetupleandkeywords#c.PyArg_ParseTupleAndKeywords
                On 26/04/2017 at 02:38, xxxxxxxx wrote:
                Hi Miro,
                To parse a BaseList based object, use 'G' format character as show in my above code snippet's function  extendpyapi_PassBaseList(). The object can be casted to the most interesting type after retrieving it.
                PythonLibrary::ParseTupleAndKeywords() accepts the following format characters for Cinema 4D C++ API classes:
                - $: String
                - %: Filename
                - M: Matrix
                - V: Vector
                - Q: Quaternion
                - 😄 BaseContainer*
                - G: GeData (versatile: can parse a BaseList, a custom data, a time, etc.)
                - T: BaseTime
                - X: BaseThread
                PythonLibrary::ParseTupleAndKeywords()also accepts the following standard format characters: b, B, j, h, i, I, v, l, L, r, f, d, c
                  On 27/04/2017 at 23:34, xxxxxxxx wrote:
                  That's perfect! Thank you.
                    On 24/09/2017 at 13:07, xxxxxxxx wrote:
                    Hello all,
                    It seems to be that i's only possible to make a python extension library as a plugin. Which plugin then is best suited? A command plugin, I would guess, or is there another plugin that loads completely automatic at startup?
                    I need something that is always available, so that I don't have to think about loading the library. Much like the c++ example here: page_creating_libraries.html
                    Regards,
                    Hermen
                      On 25/09/2017 at 01:29, xxxxxxxx wrote:
                      a "_ plugin_" is just a custom module loaded by Cinema. So a "plugin" does not need to include anything e.g. a command data extension. You only have to implement PluginStart()/PluginMessage()/PluginEnd(), see Plugin Functions Manual. In such a PluginMessage () function you have to register your Python extension as shown above.
                        On 25/09/2017 at 02:53, xxxxxxxx wrote:
                        Aha!
                        Now I understand, thanks for clearing that up!
                        regards,
                        Hermen
