    Serial.cpp
    6 Posts 0 Posters 819 Views
      On 21/02/2003 at 07:25, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Does anybody know how to use that project example? I made it run, but to be honest I don´t understand what the routine checks for. What does the user have to input in the dialog to make the example serial checking succeed? (something with TEST- but then?? Don´t get it)
      Any help appreciated. Rob? 🙂
      Best
      Samir
        On 22/02/2003 at 23:51, xxxxxxxx wrote:
        If the example is so confusing it's probably easier to write your own. There are no unique ideas in that code. But I think that the number must begin with "TEST" and a number.
        You only have to note the ReadPluginInfo()/WritePluginInfo() calls to store encrypted information. The rest is just dialog management, afaict.
        (C'mon, hackers have long been able to circumvent and reverse engineer serial schemes with a debugger only. And here you have the whole source code at your disposal... 😉
          On 23/02/2003 at 04:05, xxxxxxxx wrote:
          yes, I have already. 🙂 Thanks anyway
            On 16/05/2004 at 18:54, xxxxxxxx wrote:
            Howdy,
            What about the line:
            #define MYPLUGIN_ID    9999999 // CHANGE THIS !!!!
            Is this supposed to be a new ID from Plugin Cafe or the current ID of the plugin to be registered.
            What if there are several IDs in a plugin suite?
            Adios,
            Cactus Dan
              On 17/05/2004 at 06:25, xxxxxxxx wrote:
              That's a new unique ID, for the serial number part of the plugin.
                On 17/05/2004 at 14:18, xxxxxxxx wrote:
                Howdy,
                Thanks, Mikael.
                Adios,
                Cactus Dan
