    Seperator Tag Plugin
    20 Posts 0 Posters 1.7k Views
      On 04/06/2016 at 16:56, xxxxxxxx wrote:
      It's been a very long time since I've used COFFEE. So I could be wrong about this.
      But if I remember correctly. COFFEE can't make tag plugin's that have an AM GUI.
      Someone please correct me if I'm wrong.
      I can show you how to manipulate the host object with a GeDialog that pops up when you click on the tag if you want.  But AFAIK AM GUI's are not possible with COFFEE.
      You're going to keep on running into these limitations with COFFEE. It's fairly weak at making plugins.
      C++ was really the only good plugin writing option in C4D before Python came along.
        Thank you for your help & your patience. It would be awesome if you could show me GeDialog manipulation, please. Would it be difficult to make it non-modal? The reason I initially wanted it in the AM, is because I'd like to lock it & select maps from the list that I mentioned I wanted to put into the interface. With a non-modal dialog, I wouldn't need the AM interface because I'd be able to have the dialog float and select maps from the list without having to double-click on the tag everytime.
          On 05/06/2016 at 11:16, xxxxxxxx wrote:
          I don't think you can use a non modal dialog that way.
          A tag's AM GUI is linked to the object the tag is on via descriptions. And if you did that with an Async GeDialog you would probably lock up C4D. Because GeDialogs run in the main thread. Thus blocking the user from doing anything. Even if it was set to Async.
          A dialog typically needs to execute some task/tasks and then finish. Not run continuously like an expression or a tag.
          You might be better off writing a GeDialog plugin that's in the plugins folder. And make it target the active object. Just don't try to make the dialog continuously execute like a tag.
          Here is an example of a tag plugin with a dialog.
          But the dialog is modal.
          //This is a sample plugin that opens a dialog when the tag is double clicked so you can attach GUI items to the tags using Coffee
          //INSTRUCTIONS:
          //Create a new folder named whatever you want
          //Copy all of this code into a text file with the file extension .cof and put it in that folder
          //Create a 32x32 .tif image named "plugintagicon.tif" and put it that folder
          //Then put the folder in your C4D plugins folder
          const var PLUGIN_ID = 10000009; // THIS id IS FOR TESTING PURPOSES ONLY!!!!
          enum // Assigns id numbers to your GUI items so you don't have to create them on the fly later on
            PLUGIN_DIALOG = 10000,
            group1,
            X_POSITION,
            Y_POSITION,
            Z_POSITION,
            X_ROTATION,
            Y_ROTATION,
            Z_ROTATION,
            METHOD_TYPE,
            METHOD_ENABLE,
            _DUMMY01_
          //A custom method that moves and rotates the object this tag plugin is on
          DoThis(obj, bc)
            //Sets the position of the obj
            var pos = obj->GetPosition();
            pos.x = bc->GetFloat(X_POSITION);
            pos.y = bc->GetFloat(Y_POSITION);
            pos.z = bc->GetFloat(Z_POSITION);
            obj->SetPosition(pos);
            obj->Message(MSG_UPDATE);
            var rot = obj->GetRotation();
            rot.x = bc->GetFloat(X_ROTATION);
            rot.y = bc->GetFloat(Y_ROTATION);
            rot.z = bc->GetFloat(Z_ROTATION);
            obj->SetRotation(rot);
          //The dialog class for the plugin
          class PluginDialog : GeModalDialog
            var bc;
            PluginDialog();
            GetContainer();
            SetContainer(_bc);
            CreateLayout();
            Init();
            Command(id, msg);
            private:
            ContainerToDialog();
            DialogToContainer();
          PluginDialog::PluginDialog()
            super();
            bc = new(BaseContainer);
          PluginDialog::GetContainer() { return bc->GetClone(); }
          PluginDialog::SetContainer(_bc) { bc = _bc->GetClone(); }
          PluginDialog::CreateLayout()
            AddGroupBeginV(800, BFV_SCALEFIT, 1, "Position Group", 0);
            AddGroupBorder(BORDER_GROUP_IN);
            AddGroupBorderSpace(10, 10, 10, 10);
            AddGroupSpace(4, 4);
            AddGroupBeginH(group1, BFH_SCALEFIT, 3, "X slider", 0);
            AddStaticText(0,BFH_LEFT,0,0,"X Position",0);
            AddEditSlider(X_POSITION, BFH_SCALEFIT, 100, 10); //id, flags, width,height
            AddGroupBeginH(group1, BFH_SCALEFIT, 3, "Y slider", 0);
            AddStaticText(0,BFH_LEFT,0,0,"Y Position",0);
            AddEditSlider(Y_POSITION, BFH_SCALEFIT, 100, 10); //id, flags, width,height
            AddGroupBeginH(group1, BFH_SCALEFIT, 3, "Z slider", 0);
            AddStaticText(0,BFH_LEFT,0,0,"Z Position",0);
            AddEditSlider(Z_POSITION, BFH_SCALEFIT, 100, 10); //id, flags, width,height
            AddGroupEnd();
            AddGroupEnd();
            AddGroupEnd();
            AddGroupEnd();
            AddGroupBeginV(800, BFV_SCALEFIT, 1, "Rotation Group", 0);
            AddStaticText(0,BFH_LEFT,0,0,"Y Rotation",0);
            AddEditSlider(X_ROTATION, BFH_SCALEFIT, 100, 10); //id, flags, width,height
            AddStaticText(0,BFH_LEFT,0,0,"X Rotation",0);
            AddEditSlider(Y_ROTATION, BFH_SCALEFIT, 100, 10); //id, flags, width,height
            AddStaticText(0,BFH_LEFT,0,0,"Z Rotation",0);
            AddEditSlider(Z_ROTATION, BFH_SCALEFIT, 100, 10); //id, flags, width,height
            AddGroupEnd();
            AddGroupEnd();
            AddGroupEnd();
            AddGroupEnd();
            AddDlgGroup(DR_DLGGROUP_OK);
            AddDlgGroup(DR_DLGGROUP_CANCEL);
          PluginDialog::Init()
          PluginDialog::ContainerToDialog()
            //Transfer data from the container to the dialog
            SetMeter(X_POSITION, bc->GetFloat(X_POSITION), -1000, 1000, .1); // id, value, min, max, step
            SetMeter(Y_POSITION, bc->GetFloat(Y_POSITION), -1000, 1000, .1); // id, value, min, max, step
            SetMeter(Z_POSITION, bc->GetFloat(Z_POSITION), -1000, 1000, .1); // id, value, min, max, step
            SetRadians(X_ROTATION, bc->GetFloat(X_ROTATION), -6.28319, 6.28319, .0174533); // id, value, min, max, step
            SetRadians(Y_ROTATION, bc->GetFloat(Y_ROTATION), -6.28319, 6.28319, .0174533); // id, value, min, max, step
            SetRadians(Z_ROTATION, bc->GetFloat(Z_ROTATION), -6.28319, 6.28319, .0174533); // id, value, min, max, step
            Enable(METHOD_TYPE, bc->GetInt(METHOD_ENABLE, FALSE));
          PluginDialog::DialogToContainer()
            //Transfer data from the dialog to the container
            bc->SetData(X_POSITION, GetMeter(X_POSITION));
            bc->SetData(Y_POSITION, GetMeter(Y_POSITION));
            bc->SetData(Z_POSITION, GetMeter(Z_POSITION));
            bc->SetData(X_ROTATION, GetRadians(X_ROTATION));
            bc->SetData(Y_ROTATION, GetRadians(Y_ROTATION));
            bc->SetData(Z_ROTATION, GetRadians(Z_ROTATION));
            bc->SetData(METHOD_TYPE, GetItem(METHOD_TYPE));
          PluginDialog::Command(id, msg)
            DialogToContainer(); //Get the current state
          //The Tag's class
          var tagIcon;
          class MyExpressionTag : ExpressionPluginTag
            MyExpressionTag();
            GetID();
            GetIcon();
            MultipleAllowed();
            DisplayAllowed();
            GetHelpText();
            Edit();
            Execute(doc, op);
            UseMenu();
            GetName();
          MyExpressionTag::MyExpressionTag() { super(); }
          MyExpressionTag::GetID()               { return PLUGIN_ID; }
          MyExpressionTag::GetIcon()             { return tagIcon; }
          MyExpressionTag::MultipleAllowed()     { return TRUE; } //Don't allow multiple tags
          MyExpressionTag::DisplayAllowed()      { return TRUE; }
          MyExpressionTag::GetHelpText()         { return "My GUI Coffee Tag Plugin"; }
          MyExpressionTag::UseMenu() { return TRUE; }
          MyExpressionTag::GetName() { return "My GUI Tag"; }
          MyExpressionTag::Edit()
            //This function executes only when the open tag dialog is closed using the Enter action
            var bc = GetContainer();
            bc->SetData(METHOD_ENABLE, FALSE);
            var dialog = new(PluginDialog);
            dialog->SetContainer(bc);
            dialog->Open(-1,-1);
            if (dialog->GetResult())
                SetContainer(dialog->GetContainer());
            else return FALSE;
          MyExpressionTag::Execute(doc, op)
            //This function executes when the timeline is running. Or something is changed in the scene
            //If you need to monitor an object's current state. This is where to put the code.
            DoThis(op, GetContainer());
          //This section registers the plugin with C4D
            // Get the icon
            var fn = GeGetRootFilename();
            fn->RemoveLast();
            fn->AddLast("plugintagicon.tif"); //<----Change this to your own image file
            tagIcon = new(BaseBitmap,1,1);
            tagIcon->Load(fn);
            Register(MyExpressionTag);
            Wow, that is very, very kind of you, thank you so much. I'm very sure this will help me immensely.
            Thank you
              On 07/06/2016 at 04:26, xxxxxxxx wrote:
              Not 100% sure if Scott was saying the same thing: You can make the dialog exchange data with the tag,
              and the tag does its work as an expression. You can make a button in the Tag's description (ie. in the
              attribute manager) to open the dialog that edits the tag (similar to the Expression Editor for COFFEE and
              Python Tags/Python Generators).
                attribute manager) to open the dialog that edits the tag).
                According to my notes. We can't do that with COFFEE. It's not supported.
                I think this question was as asked on CGTalk a long time ago. And that's where I got the "Not Supported" answer from.
                  On 07/06/2016 at 07:55, xxxxxxxx wrote:
                  My bad for not recognizing it's about COFFEE. 😊 You're example that implements PluginTag::Edit()
                  is probably the best available option then. 🙂
                    On 10/06/2016 at 05:10, xxxxxxxx wrote:
                    Scott & NiklasR, thank you very much for your replies and sorry for only replying now.
                    It only occurred to me last night that there's a free COFFEE plugin which has a dialog setup exactly like what I want to make with mine. The dialog of Fabian's MirrorPointPosition plugin has a non-modal dialog when you double-click on the plugin. However, even though he kindly supplies the COFFEE code with his plugin, his scripting skills are so many light years beyond mine that I can't seem to figure out how he does it.
                      On 10/06/2016 at 08:02, xxxxxxxx wrote:
                      I took a quick look at that plugin's code. And he's doing what I said earlier about using a GeDialog to target the active object. Only he goes one step farther, and targets a custom tag on the active object.
                      The tag in his plugin is only there to hold some data.
                      C4D creates these kinds of vertex tags automatically when you make a new object. But they are hidden by default.
                      But you can also make your own tag to hold the data like he did.
                      The key components are:
                      1- GeDialog class: The non modal dialog with all the gizmos in it
                      2- Command class: Launches the GeDialog from the C4D plugins menu (hosts the GeDialog when it's closed)
                      3- ExpressionPluginTag class: The tag plugin
                      Depending on what you want to do. You might not need the tag plugin part. It's only there to hold some specific data.
                      But in any case. If you want to write plugins in any language. You will need to get a good grip on writing classes and class methods.
                      Scripts don't use classes very often. But that's what plugins are all about. Classes and methods.
                      There's a ton of tutorials about that on the internet. But it will probably take you a bit of head banging before it finally clicks. It's a necessary thing to learn to make plugins.
                        Hi Scott
                        Thank you very much for having a look at the code and giving your insights.
                        I suspected that a full fledged plugin would be much more complex than the scripts I've been delving into. It appears I'll have to start looking into C++ as that will also help me overcome some of the limitations associated with COFFEE. However, just the thought of it, makes my hair stand on end. I think I'll have to follow your course on Youtube to begin with and work from there but that will have to wait untill I've got more time on my hands. Untill then I'll see if I can grasp the classes and stuff as that really makes my head spin.
                        Thanks again.
                          On 10/06/2016 at 17:21, xxxxxxxx wrote:
                          Many of COFFEEs limitations can be circumvented with Python already. While it's still limiting in some areas, it's certainly powerful in most others.
                            On 10/06/2016 at 18:00, xxxxxxxx wrote:
                            And the slight learning curve for Python and the C4D Python API is well worth the power gained over COFFEE.
                              On 10/06/2016 at 18:18, xxxxxxxx wrote:
                              He's stuck with R12 which doesn't support Python.
                              So Python is not an option for him guys.
                                On 10/06/2016 at 18:24, xxxxxxxx wrote:
                                There was Py4D but it wasn't integrated into C4D yet and probably not totally compatible with the integrated API, I agree.
                                  On 13/06/2016 at 08:51, xxxxxxxx wrote:
                                  Hey guys,
                                  nice discussion you have going on here.
                                  Not sure the SDK team can contribute much more here.
                                  In general we recommend to use the latest version of C4D (which seems to be no option here) and from our point of view Python would be the road to go. Also we can support only the latest version of C4D. While we usually try to stretch this rule as far as possible, I'm afraid R12 or even R10.5 are completely out of our scope. Sorry.
                                    On 13/06/2016 at 23:08, xxxxxxxx wrote:
                                    Thank you to everyone who responded. I really appreciate the help & insights tremendously.
                                    Hey guys,
                                    Hi Andreas
                                    I didn't intend to upset the forum guidelines so could you please clarify: Should I rather not pose questions about COFFEE scripting here? Should I rather post on a 3rd party forum like CGTalk? I don't think my question was version specific and I only mentioned my version situation so that it would be clear that I was specifically seeking COFFEE help.
                                      On 14/06/2016 at 00:37, xxxxxxxx wrote:
                                      Hi Uncle-Ox,
                                      I'm sorry, that wasn't my intention.
                                      You didn't upset any forum guidelines. Everything's alright. It's fine to post COFFEE questions in here. I just wanted to say, that we have no better ideas, than already discussed.
                                      And of course you are also free to discuss older versions (only partly the case here, I know), even if the SDK team might not be able to help in such cases.
