    BaseMaterial Compare
    5 Posts 0 Posters 785 Views
      On 21/02/2003 at 06:56, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      For BaseMaterials we have the function  Compare . this compares 2 materials and reports either true , if they are the same or false if not the same.
      this function works most of the time.But it is fatally flawed.
      if you compare 2 volume shaders(of same type)  from SLA which are clearly different , it will report them as being the same!!!!
      this is a very nasty bug and renders the compare function useless.
      I have tried to catch the exeption and compare the basecontainers form the 2 materials , however these also report "same"
      the materials are clearly not the same , so this must be a bug.
      can someone offer a workaround or please fix it 🙂
      there seems to be no way to tell 2 sla volume shaders  apart !!!!
        On 21/02/2003 at 07:19, xxxxxxxx wrote:
        did you try gettype()? They should have different ids that will make them comparable.
        Best
        Samir
          On 21/02/2003 at 07:35, xxxxxxxx wrote:
          gettypew is not usefull for materials as they are all the same
          but I can use mat->GetNodeID() which gives 0 for a normal material
          and the plugin id of the for  any plugin shaders, like SLA vloumes
          this doesnt help if i have 2  vlume plugins , which are the same.
          I then do compare on them and it tells me they are the same , when they are not . (1e, 1 blue , 1 red)
          so I test containers as well to make sure , but this also says they are the same.
          so something is broken , its not possible to compare 2 CHEEN shaders.
          the result is always true .(same) if the they match or not.
            On 21/02/2003 at 16:29, xxxxxxxx wrote:
            ah, have missed the point. Thought you were trying to compare two volume shader but didn´t know you were talking same type!
            Good luck!
              On 22/02/2003 at 23:45, xxxxxxxx wrote:
              This is not a bug. The MaterialData hook has no comparison function, so BaseMaterial::Compare() cannot compare the private data of two R7 shaders. (Cf. CHANNELSHADER::CompareSettings() in R7.)
              I'll write a suggestion about it.
