    Modify Reflectance Layer Parameter
    2 Posts 0 Posters 301 Views
      On 27/05/2016 at 03:34, xxxxxxxx wrote:
      Can someone give me an example how I can set Parameter in a Reflectance Layer?
      I need to set parameter like roughness and Color.
        On 03/06/2016 at 08:45, xxxxxxxx wrote:
        to edit a parameter of a reflection layer you have to construct the specific parameter ID using the data ID of the given layer and the parameter ID that is defined in the c4d_reflection.h header file. This is some simple example:
        # create a new layer
        layer = mat.AddReflectionLayer()
        if layer is not None:
          # configure layer
          layerID = layer.GetDataID()
          layer.name = "Gold Layer"
          layer.flags = c4d.REFLECTION_FLAG_SELECTED  | c4d.REFLECTION_FLAG_TAB | c4d.REFLECTION_FLAG_ACTIVE
          mat.SetParameter(layerID + c4d.REFLECTION_LAYER_FRESNEL_MODE, c4d.REFLECTION_FRESNEL_CONDUCTOR, c4d.DESCFLAGS_SET_0)
          mat.SetParameter(layerID + c4d.REFLECTION_LAYER_FRESNEL_METAL, c4d.REFLECTION_FRESNEL_METAL_GOLD, c4d.DESCFLAGS_SET_0)
