    SCALE_V in VideoPost description
    2 Posts 0 Posters 243 Views
      On 11/05/2016 at 10:07, xxxxxxxx wrote:
      Cinema 4D Version:   R13-R17
      I have a problem with SCALE_V in resource of VideoPost, here is example code
      CONTAINER vpmyvideopost
          NAME vpmyvideopost;
          INCLUDE VPbase;
          GROUP ID_VIDEOPOSTPROPERTIES
              DEFAULT 1;
              SCALE_V;
              STRING MY_SCALED_EDIT { CUSTOMGUI MULTISTRING; SCALE_V; }
      Desired effect is to have MY_SCALE_EDIT scaled vertically across whole window in Render Settings, but I get only default height.
      Because the same method works in drendersettings.res (for RDATA_HELPTEXT), I guess it is because render settings uses CustomDescriptionGui to show VP settings and this element doesn't have SCALE_V set. If so, is there some way to set it from within VP plugin?
      Note that in my real code, I don't use MULTISTRING but my own iCustomGui, so if there is a way to get the height of parent dialog (the second column in render settings), it would also be solution as I could simply compute correct height and set it in main group.
        On 13/05/2016 at 08:59, xxxxxxxx wrote:
        I'm afraid this looks like a limitation of the Render Settings dialog setup.
        The same parameter definition for an Object plugin works as expected in the Attribute Manager i.e. the edit text scales vertically as expected.
