    Load/Save Materials [SOLVED]
    5 Posts 0 Posters 561 Views
      On 09/05/2016 at 06:49, xxxxxxxx wrote:
      Cinema 4D Version:   R16+
      Part of my current project will involve loading and saving of Presets.  The Presets will include material information associated with the current settings. Instead of just saving out particular channel settings and texture images (to be reconstructed and possibly missing user-set information), it would be better to save actual materials.  And I realize that C4D can save and load materials using the Material Manager but there doesn't appear to be any API support.  The material 'files' themselves would be referenced by the Preset file (by relative path).
      What suggestions do you have?
        On 09/05/2016 at 10:11, xxxxxxxx wrote:
        You could just create a basedocument, insert the material and save that document (with only the material in it) I guess.
          On 09/05/2016 at 14:17, xxxxxxxx wrote:
          That might be the only satisfactory solution.  Appears as if the file saved from the Material Manager is a .c4d document file though it doesn't include the extension.
            On 10/05/2016 at 01:19, xxxxxxxx wrote:
            the "Save Materials as..." function indeed just saves a BaseDocument containing the materials. This should be easily reproducible with the API.
              On 10/05/2016 at 15:00, xxxxxxxx wrote:
              Thanks, Sebastian and Samir.  You can mark this as 'SOLVED'. 🙂
