    Not reading ESC key
    30 Posts 0 Posters 17.8k Views
      On 02/05/2016 at 08:56, xxxxxxxx wrote:
      Well, it only calculates if the points change
      So, once the calculation is done and there is no changes in the number or location of the vertexes, it just returns c4d.EXECUTIONRESULT_OK
      Anyway, having it in a separate thread made it more efficient and I seem to be able to detect the ESC key now. I just have to use the bt thread to do it (thank you, Scott, Sebastian and Niklas).
      Now I just have to fine tune the code to make it calculate only when it is needed, after the user halts it with ESC.
        On 02/05/2016 at 09:00, xxxxxxxx wrote:
        Sure it can safely take as much time as it needs. Only it will be annoying to the user if it takes too
        much time. Just look at dynamics, they'll take many seconds per frame on a very large scene, too.
        (And that they are computed from a SceneHook instead of a Tag plugin doesn't make a difference here).
        -Niklas
          On 02/05/2016 at 09:03, xxxxxxxx wrote:
          Are you talking about spawning a new C4DThread? I strongly believe that this won't be more efficient.
          If anything, it should be the same performance (+ the overhead for spawning and waiting on the
          thread) unless you're doing multithreading, which you can't in Python unless you do actual multiprocessing.
            On 02/05/2016 at 09:09, xxxxxxxx wrote:
            By "more efficient" I mean that as I adjust the parameters, the calculation stops and it starts again with the new values.
            When it was in the main thread, I had to wait until the calculation was over (anything between .3 seconds to 20+ seconds) to adjust the parameters and see the new result.
              On 02/05/2016 at 10:08, xxxxxxxx wrote:
              Are you calling C4DThread.Wait() from Execute() (where I assume you are also starting the thread)?
              Because you should. And if you check bt.TestBreak() frequently enough (thought you shouldn't do it
              too frequently as it'll have performance impacts) you should get the same result ("responsiveness")
                On 02/05/2016 at 10:45, xxxxxxxx wrote:
                That is exactly what I'm doing
                I'm still performing tests (to try to break it or spot any bugs) but it is working fine, so far.
                  On 02/05/2016 at 11:36, xxxxxxxx wrote:
                  I would love to see an actual example of this. Because I still don't see how you can catch a keypress in the Execute() method while the timeline is not moving?
                  And I don't see how using bt.TestBreak() solves that?
                    On 02/05/2016 at 14:11, xxxxxxxx wrote:
                    It goes something like this:
                    class MyThread(c4d.threading.C4DThread) :
                         bt = None
                         def Main(self) :
                              if self.bt.TestBreak() : return
                    class my_plugin(plugins.TagData) :
                         thread = MyThread()
                         def Execute(self,tag,doc,op,bt,priority,flags) :
                              MyThread.bt = bt
                              self.thread.Start()
                              self.thread.Wait()
                      On 02/05/2016 at 15:10, xxxxxxxx wrote:
                      I'm trying to do this without making a new thread.
                      Nicklas said we don't have to make a new thread. Just use bt.TestBreak(). But I don't see how to do that where it would allow us to capture a keypress.
                        On 02/05/2016 at 15:25, xxxxxxxx wrote:
                        Well, I don't know either
                        It is working for me, inside my user thread. But having a user thread is better in my particular case.
                        As it is now, it seems to only check for Esc (luckily for me, it is what I want). But I would also like to know how to override the main TestBreak() method.
                          On 03/05/2016 at 01:27, xxxxxxxx wrote:
                          The BaseThread comes from the "Cinema 4D Core". It's implementation of TestBreak() does something like
                          checking if the ESC key is pressed and returns True or False accordingly. Very likely, the event is saved somewhere
                          in a queue or synchronized data structure from the main thread (since the thread itself can't check if the
                          key is pressed, as we already figured).
                          You're bound to the Cinema 4D way of cancelling such actions (ie. the ESC key) as you can not tell the
                          BaseThread to check a different key in TestBreak() (that is hard coded somewhere in the C4D source
                          where TagData.Execute() is called, since the BaseThread is passed to that function and can not be changed).
                          It's the same mechanic to when you use the RenderDocument() function and pass it your own C4DThread,
                          only that the context is reversed. Here, you call TestBreak() to check if the processing should stop, but
                          the implementation of TestBreak() is not accessible to you. In RenderDocument(), it will call TestBreak()
                          to check if the rendering should be aborted, and you can specify at what event exactly the rendering
                          should stop by implemented C4DThread.TestDBreak().
                            On 03/05/2016 at 08:23, xxxxxxxx wrote:
                            That matches with what I'm seeing Niklas.
                            It all comes down to GUI thread blocking. And the only way to get around it is to make your own thread.
                            However...I still think it's a horrible idea to do this in a tag plugin.
                            There's a good reason why some tags have a cache button on them. To do the number crunching and fill the tag with data first. Before the rest of the tag code is executed. Not doing them all at the same time. And then trying to stop it in mid execution if it takes too long.
                            But I constantly break the rules myself. So I'm not in any position to throw stones. 😉
                              I am not sure I understand you correctly. Could you elaborate in more detail why you would need your own thread?
                              It usually all depends on numbers. If you accidentally cranked up that Subdivision Surface parameter
                              into the nirvana, you're happy when you can stop the calculation by pressing the ESC key instead of
                              waiting forever or shutting down your PC by force due to low/no free RAM.
                              IMHO there is no general rule like "don't crunch too hard in Execute()", it just depends on what you're
                              trying to accomplish, what the tag is doing/ must  be doing every frame, if it doesn't have the ability to
                              do precalculations in any way.
                              -Niklas
                                On 03/05/2016 at 09:17, xxxxxxxx wrote:
                                It's like you just said.
                                There seems to be no way to catch a keypress (other than maybe Esc) unless we make our own thread.
                                But I can't catch the Esc keypress from within the Execute() method using just the bt thread either.
                                AFAIK. The subdivisions tag never "stops".
                                The attributes are set to only accept a maximum of 1000 to prevent crashing.
                                I don't know of any tag that actually "stops" the code execution using the bt thread. The very idea seems wrong headed to me.
                                So if there is such a thing. I'd love to see an example of it.
