    Polygons facing each other [SOLVED]
    6 Posts 0 Posters 545 Views
      On 28/04/2016 at 15:23, xxxxxxxx wrote:
      I have a list with all the normals of all the polygons of an object, that I calculated with this code:
      for p in polygons:
           a,b,d = points[p.a],points[p.b],points[p.d]
           normals.append((b - a).Cross(d - a).GetNormalized())
      With this information available, how can I check if two faces are:
      - roughly facing each other
      - roughly facing in the same direction
      - roughly facing opposite directions
        On 29/04/2016 at 11:00, xxxxxxxx wrote:
        These are the possible cases. How can I detect them all? Anyone?
        http://s32.postimg.org/q1libis7p/Normals.jpg
          On 29/04/2016 at 12:43, xxxxxxxx wrote:
          You can compute the angle between the normal vectors of the polygons using the dot product.
            On 29/04/2016 at 12:50, xxxxxxxx wrote:
            I know that, Niklas.
            But in my image, for example, the angles between the normals in the second and third case is the same: around 180°
            How can I differentiate them?
              On 29/04/2016 at 15:45, xxxxxxxx wrote:
              I guess I found a way.
              If the angle between the normal is less than 90°, they are pointing in the same general direction.
              If the angle is between 90° and 180°, I check if a point of one of the polygons(the center of a polygon) is in front of the other polygon or not.
              If it is, the polygons are facing each other.
              if not, they are facing in opposite directions.
              Am I right?
                On 30/04/2016 at 12:39, xxxxxxxx wrote:
                Just to let everyone know that it worked
