    Get hair data from HairObject
    2 Posts 0 Posters 274 Views
      On 24/04/2016 at 12:35, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Hello.
      I have a HairObject with 10 guides that generates 1000 splines (based on the guides).
      I use the following code to retrieve information about the guides:
      HairObject* hair_object = static_cast<HairObject*>(object);
      HairGuides* guides = hair_object->GetGuides();
      How can I get information about the actual hair ?
      What I need is a data structure that contains 1000 splines, so I can parse every point of each spline.
      Is there any example on how to do that ?
      Thank you very much.
        On 25/04/2016 at 02:11, xxxxxxxx wrote:
        to access the points that define the hairs stored in a Hair object you have to call GenerateHair(). Please notice that you have to call this inside a pair of Lock() and Unlock().
        You find an example how to use this in this thread:
        • Generating Hair
