    Get all the Neighbors until a set distance
    12 Posts 0 Posters 1.1k Views
      On 25/04/2016 at 03:09, xxxxxxxx wrote:
      Here is an optimized version, using sets.
      from sets import Set
      def get_near(p_center,distance,centers,pli,nbr) :
          near=Set(pli)
          pli=Set(pli)
          added=True
          while added:
              added=False
              for poly in pli:
                  poly_info=nbr.GetPolyInfo(poly)
                  new_pli=Set(poly_info['face'])-near
                  for poly2 in new_pli:
                     if poly2!=c4d.NOTOK:
                          if poly2 not in near:
                              if (centers[poly2]-p_center).GetLength()<=distance:
                                  near.add(poly2)
                                  added=True
              pli=near-pli
          return near
        On 25/04/2016 at 10:46, xxxxxxxx wrote:
        Hi Rui,
        Do you happen to have a more complete example of this?
        I would like to compare it to the get all points version I have. But I'm having trouble creating some of your required parameters (p_center, centers, & pli).
          On 25/04/2016 at 11:18, xxxxxxxx wrote:
          I will provide you with the code and required info to get what you need, Scott
          My code starts in a vertex and returns a list of polygons that at connected to that vertex until a specific distance.
          p_center is just the coordinates of the vertex (in local space) where the search will start.
          centers is a list of all the center coordinates of all polygons in the object (in local coordinates) and I got those pre-calculated with the following code:
              points = obj.GetAllPoints()
              polygons = obj.GetAllPolygons()
              centers = []
              for p in polygons:
                  centers.append((points[p.a]+points[p.b]+points[p.c]+points[p.d])*.25)
          I used *.25 instead of /4 because multiplications are usually faster than divisions, in python.
          The pli was got from:
          nbr = utils.Neighbor()
          nbr.Init(obj)
          pli = nbr.GetPointPolys(i)
          Where i is the index of the starting point (the one that I got the p_center from).
          So, when I call get_near , I have the coordinates of index point i in p_center , the distance is the maximum distance from p_center to consider, centers is a list with all the polygon centers, pli is a list containing the first set of faces around the point with index i and nbr is the Neighbor structure initialized for my object.
          I tried to make my get_near code as fast as I could but, if someone knows how to make it faster, please tell me
            On 25/04/2016 at 11:47, xxxxxxxx wrote:
            Thanks.
            If you're using: point = obj.GetAllPoints() in your code.
            Then I'm not sure if you are gaining any speed in your code by doing all the neighbor stuff.
            Here is the version I have in my notes.
            But I don't know if this is slower, or faster, than yours.
              obj = doc.GetActiveObject()
              if not obj: return False
              pointCount = obj.GetPointCount()
              selectedPoints = obj.GetPointS()
              #Only allow the script to run if one point is selected
              if selectedPoints.GetCount() != 1: return False
              sourcePntID = None
              sourcePntPos = None
              for i, v in enumerate(selectedPoints.GetAll(pointCount)) :
                  if not v: continue         #Skip over the non selected points
                  sourcePntID = i
                  sourcePntPos = obj.GetPoint(i)
              radius = 50   #The radius surrounding the source point's position
              #Select the surroung points if they are within the radius distance
              for id, pos in enumerate(points) :
                  deltaX = abs(sourcePntPos.x - pos.x)
                  deltaY = abs(sourcePntPos.y - pos.y)
                  deltaZ = abs(sourcePntPos.z - pos.z)
                  if deltaX <= radius and deltaY <= radius and deltaZ <= radius:
                      #print id
                      selectedPoints.Select(id)
              On 25/04/2016 at 11:53, xxxxxxxx wrote:
              Well, I was searching for faces, not points.
              But I will see if I can implement the simpler version with points.
              Thank you, Scott.
                On 25/04/2016 at 15:06, xxxxxxxx wrote:
                Just performed a test and, amazingly, with a mesh of 10201 vertexes (10000 polygons), using my method, it took 0.5 seconds and using a "go through all the list" method, it took 8.2 seconds.
                Because I need to go through the entire list for each vertex. So, with a "go through all the list" I get N * N interactions.
                This means that all vertexes are dealt with, as if they all had the same amount of possible relation with the starting point. In fact, statistically, they all are equal candidates.
                With my method, the search starts in the point itself and it only goes through the adjacent polygons until no more candidates fulfill the requirements. As soon as no polygon center is within the maximum distance, it stops.
                I managed to make it all a little faster by checking for GetLengthSquared(), instead of GetLength()
                  On 25/04/2016 at 15:23, xxxxxxxx wrote:
                  I still can't figure out how to make your custom method work. I'm getting "requires an int" error from it.
                  I'm using it on a sphere targeting point #141 as the starting point.
                  from c4d import utils
                  def getNearestPoly(p_center, distance, polygons, centers, pli, nbr) :
                    near = pli
                    added = True
                    while added==True:
                        added = False
                        for poly in pli:
                            poly_info = nbr.GetPolyInfo(poly)
                            new_pli = poly_info['face']
                                if poly2 != c4d.NOTOK:
                                    length = (centers[poly2]-p_center).GetLength()
                                    if length <= distance:
                                            near.append(poly2)
                                            added = True
                        pli = near
                    return near
                    if obj is None: return
                    nbr.Init(obj)
                    pli = None
                    for i in xrange(obj.GetPolygonCount()) :
                        pli = nbr.GetPolyInfo(i)
                    centers = []
                    for p in polygons:
                    p_center = obj.GetPoint(141)
                    distance = 10
                    getNearestPoly(p_center, distance, polygons, centers, pli, nbr) #Error!!
                    On 25/04/2016 at 16:13, xxxxxxxx wrote:
                    Try this, and change the distance variable.
                    def getNearestPoly(p_center,distance,centers,pli,nbr) :
                        near=set(pli)
                        pli=set(pli)
                        added=True
                        while added:
                            added=False
                            for poly in pli:
                                new_pli=set(poly_info['face'])-near
                                                near.add(poly2)
                                                added=True
                            pli=near-pli
                        return near
                        nbr.Init(obj)
                        centers = []
                        for p in polygons:
                        pli = nbr.GetPointPolys(141)
                        distance = 30
                        near=getNearestPoly(p_center, distance, centers, pli, nbr)
                        print near
                      On 25/04/2016 at 16:21, xxxxxxxx wrote:
                      Oh, the error was occurring because you had to start with pli equal to nbr.GetPointPolys(i) , not nbr.GetPolyInfo(i)
                        On 25/04/2016 at 16:34, xxxxxxxx wrote:
                        Thanks. That's got it. !Thumbs Up[URL-REMOVED]
                        I knew I was doing something stupid.
