    • Admin
    Optimize + PolyReduction
    3 Posts 0 Posters 294 Views
      On 08/04/2016 at 09:32, xxxxxxxx wrote:
      Hi there,_
      Our team have created a bunch of script to automate importing CAD files into C4D. As it is well known, CA_<_o:_<_o:p_>_ can be painful to work with, often heavy with unnamed objects._<_o:_<_o:p_>_p>At some point our script apply some heavy Optimization (2 cm) + a strong PolyReduction Deformer (90%).
      So far we have experience 2 strange bug while doing those functions:
      _<_!----_>_yle="margin-left:36.0pt;text-indent:-18.0pt;mso-list:l0 level1 lfo1">1-    The PolyReduction hang on_<_!---_<_o:_<_o:p_>_cts IF the Mesh Quality Factor is higher than 0. It seams like some bad polygon are throwing the deformer in an endless loop. As anybody had similar experience?
      _<_!----_>_o:p>
      2-    The second problem is more problematic and more urgent, we sometimes have point th_<_o:_<_o:p_>_ wild._<_o:p_>_eems to be the results of the Optimization function, but I cannot reproduce the result manually. If I take the same_<_o:p_>_t, a_<_o:p_>_manually the optimization and than apply a PolyReduction NO points goes wild…
      I suspect that C4D interface command are_<_o:p_>_ mor_<_o:_<_o:p_>_ex than a simple python function (probably multiple function bundled together) since we get different result with the interface and by pure script (Using MCOMMAND_OPTIMIZE ), as if C4D had some cleaning internal process…
      Lastly we've just discovered that page:
      https://developers.maxon.net/docs/Cinema4DPythonSDK/html/modules/c4d/C4DAtom/index.html?highlight=message#C4DAtom.Message
      So none of our script contains " MSG_CHANGE". Could this be the root of our problem? Can you give us a rule of a thumb when to use them? At each function that change the ge_ <_o:_<_o:p_>_ at the end only of the script?
       And is there any other command that we have to use when changing the geometry by script?
      _.0pt;font-family:Verdana;mso-bidi-font-family:Verdana; mso-bidi-font-weight:bold">Thank you for any help you can provide 🙂
      Edit: I've changed the link in the post from NodeData to Atom.Message
        On 09/04/2016 at 10:33, xxxxxxxx wrote:
        I've made further test and it appears that it's mainly the PolyReduction that mainly causes the problem. With a reduction Below 60% the problem goes away using the scripts, Higher the problem appears.
        However no problem appears when doing the same step manually, even at 90% Reduction.
          On 11/04/2016 at 02:15, xxxxxxxx wrote:
          Hello and welcome,
          could you share your code with us? Without knowing what exactly you are doing and how you are doing it, it is hard to make any statement.
